Old 04-15-2008, 10:34 AM   #21 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
Years ago my friend was using my yard for working on his car. While he had coolant drained in the pan next to the car, neighbor dog jump the fence and drunk close to 1 gallon of it. Couple years later the neighbor was moving to the city and he gave us German Shepard (other dog was put to sleep a year earlier becouse of tumor). She lived with us for 9 years till she died of old age.
Kajtek1 is online now   Reply With Quote
Old 04-15-2008, 11:23 AM   #22 (permalink)
nugent's Avatar
Date registered: Jul 2005
Vehicle: Self: 2000 E320 83,000 mi Girlfriend: 1998 E320 134,000 mi
Originally Posted by sokoloff View Post
Remove the front noise encapsulation panel. Drain the radiator.
Len
Len, thanks for your write-up. But please indulge this newbie and explain what the "noise encapsulation panel" is, and how to remove it. More details on draining, too...
Sorry, but the instructions gave me a flashback to the recipe for rat souffle (Recipes with Rats)
nugent is offline   Reply With Quote
Old 04-16-2008, 08:16 AM   #23 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
Under the car there are three noise encapsulation panels. The center one has to come off if you drain the oil from below. The front one has to come off to access the radiator drain plug. They are all just held in place with 10mm screws. Very easy to remove them.
Open the drain plug, catch the old coolant and recycle it. Pouring it into empty gallon jugs is an easy way to measure how much you get out. There isn't much else to it on the 210 chassis. What else do you want to know?
Len
sokoloff is offline   Reply With Quote
Old 04-16-2008, 02:32 PM   #24 (permalink)
nugent's Avatar
Radiator Drain
Thanks for the clarification. I'm just not clear on the exact location of the drain plug, but I assume it will be obvious once I remove the panel.
Old 04-17-2008, 07:36 AM   #25 (permalink)
The only big old red thing under there.
Len
Please HELP! How to change radiator fluid? DYI. rcs hawaii R129 SL Class 4 02-18-2007 12:47 PM
DIY - Differential Fluid Change netdvn W210 E-Class 11 10-23-2006 02:25 AM
WTK:Instruction on change radiator fluid tb7475 W163 M-Class 7 05-22-2006 04:38 PM
When to change radiator coolant/fluid? Voortrekker W203 C-Class 2 04-06-2006 07:13 AM
Anyone have a DIY for a rear differential fluid change and seal replace? jtoma878 W208 CLK Class 0 01-24-2006 06:39 PM
