Old 07-30-2007, 11:19 AM   #11 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Designo, every engine I ever worked on had block drain plugs; I've never looked for them on the 3.2L V6, the I6 had one on the passenger side I think. That's the only way to drain all the coolant from the engine. Similiarly, every radiator I ever saw had a drain plug in it, since I can't do mine due to state regs, I've never bothered to check that either.
If pulling the lower radiator hose only nets a quart of fluid, that's a waste of time.
Obviously you've got to yank the main belly pan, so start there, then start looking for plugs/petcocks. Once they're open and you've drained it all you can close the radiator one and run fresh water in which should dump the rest out of the block. When the water's clear, turn it off and then re-open the radiator one, let them all drain out again, then close everything up and refill.
Lastly, if you have a camera take some pics and do a quick write up, this would be good for the DIY section.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 07-30-2007, 11:46 AM   #12 (permalink)
Date registered: Sep 2006
Vehicle: 2004 CLK 240
Not the same engine - but you can get the idea of how to remove a core plug from the block here:
MercedesShopWiki: Engine Block Drain Plug Removal
You will have to get underneath & have a look around for a low point on your engine block. They all look the same - generally rusty.
keyhole is offline   Reply With Quote
Old 08-01-2007, 08:59 AM   #13 (permalink)
~BANNED~
Designo_E320's Avatar
Date registered: Apr 2007
Vehicle: 2000 E320 Designo
Originally Posted by Designo_E320
Which is a better product? Water wetter or purple ice?
Shoyld I add any of these products? If so which one? If anyone has added these then what was your experience?
thanks
Designo_E320 is offline   Reply With Quote
Old 08-01-2007, 02:59 PM   #14 (permalink)
Vehicle: 2001 SLK 320(96K Miles), 2002 E320 Special Edition(113K Miles)
Just use the normal MB antifreeze/rust-inhibitor. The E320 doesn't have any problems with cooling, so it's a waste of money adding anything else. Not sure if those things may not do more harm than help in any case.
Kobus is offline   Reply With Quote
Old 08-01-2007, 03:06 PM   #15 (permalink)
Pulling the bottom hose help to get a faster outflow than draining just thru the radiator stopcock, which may help to flush out more dirt. But remember to first open the cap on the overflow bottle, so that you get a good flow. Close it up, fill with water, start & let it run until thermostat opens, shut down and drain again. Repeat a few times. I also blow in the overflow tank to empty it out completely, since the outflow suction doesn't always empty the overflow completely.
Old 08-01-2007, 04:16 PM   #16 (permalink)
Date registered: Jun 2007
Vehicle: 2002 E320 4MATIC Special Edition, Black
how offten is a flush required?
ajent420 is offline   Reply With Quote
Old 08-02-2007, 08:33 AM   #17 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
Coolant should be changed every three years.
Len
sokoloff is offline   Reply With Quote
Old 04-12-2008, 04:26 PM   #18 (permalink)
nugent's Avatar
Date registered: Jul 2005
Vehicle: Self: 2000 E320 83,000 mi Girlfriend: 1998 E320 134,000 mi
Bump on Coolant Flush DIY Request
Kobus suggested removing lower radiator hose. Is this the consensus?
Anyone care to write the definitive DIY on this topic? I would like to do a complete drain and replacement of coolant.
nugent is offline   Reply With Quote
Old 04-15-2008, 07:05 AM   #19 (permalink)
Just did mine yesterday. Capacity is 10.6 quarts. I drained about 9 or 9.5. Remove the front noise encapsulation panel. Drain the radiator. This gave me almost 8 quarts. I then disconnected the coolant lines going through the windshield washer bottle and blew air through them which forced out another quart or so of coolant. Since my coolant was the approved Mercedes coolant and it came out nice and clean and it has only been three years since I last did it, I was satisfied that was good enough, although I did dump a gallon of clean water in to flush out a little more of the old coolant. I then filled it up with Zerex G05, distilled water and Water Wetter at about a 50-50 ratio. If you've got the wrong coolant in there, if it's been a long time or if the old coolant comes out looking nasty, then you may want to go a little further and open the block drain too.
I looked at disconnecting the lower hose, but it didn't appear that would accomplish anything, since it enters the radiator right where the radiator drain is. I did disconnect the upper hose and rinsed through there and filled through there.
Len
Old 04-15-2008, 09:32 AM   #20 (permalink)
RichardM98's Avatar
Date registered: Oct 2007
Vehicle: 98 Brilliant Silver E320 Wagon
Originally Posted by gregs210 View Post
Me, I'm stuck. Coolant is a hazardous waste in CA, so you have to capture it all and dispose of it within the confines of CA's enviro laws, so that's one for which I just take it in. Too hard to flush with just water, because then you end up with several gallons of "hazardous waste" instead of a couple. And while stores here take oil, you have to pay to get rid of coolant. (sigh...)
Greg
The correct place to dispose of antifreeze in California is thru your counties' household hazardous waste program. It will be recycled. There is no charge.
RichardM98 is offline   Reply With Quote
Please HELP! How to change radiator fluid? DYI. rcs hawaii R129 SL Class 4 02-18-2007 12:47 PM
DIY - Differential Fluid Change netdvn W210 E-Class 11 10-23-2006 02:25 AM
WTK:Instruction on change radiator fluid tb7475 W163 M-Class 7 05-22-2006 04:38 PM
When to change radiator coolant/fluid? Voortrekker W203 C-Class 2 04-06-2006 07:13 AM
Anyone have a DIY for a rear differential fluid change and seal replace? jtoma878 W208 CLK Class 0 01-24-2006 06:39 PM
