Old 08-12-2007, 11:43 AM   #11 (permalink)
Premium Member
acarter53's Avatar
Date registered: Dec 2006
Vehicle: 2001 E430 Sport in Desert Silver and 2002 C320 Sport Wagon in Arctic White
Premium Member
Send a message via Yahoo to acarter53
Thumbs up
Greg,
That is excellent work.
thank you
E430 Sport
2001 E430 in Desert Silver with Sport Package, COMAND, Xenon Lights, Rear Sunshade, Heated Seats. Added K40 Stealth Radar, 30% Tint, XM Radio! www.premierbasement.com
acarter53 is offline   Reply With Quote
Old 08-13-2007, 02:41 PM   #12 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Originally Posted by cerritos
My experience: the torx screw has a little protruding index at the center. I bought a set of tool from eBay, but found out that they don't work with this type of torx screw and ended up having to go to Pepboys to buy another set.
Hey, cerritos. Hence the reference in the DIY to the "security" torx screw. That's what that dimple is in the center of the screw.
You don't need the special tip (you can use small vise-grips to grab the shoulder of the screw) but if you want it I'm told that Kragen/Checker/Shucks sells a set for like $5.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 12-13-2007, 05:02 PM   #13 (permalink)
Date registered: May 2005
Vehicle: 99CLK320
Autozone has a 9 piece saftey torx set for under $10. here's a set for $85
T5 T6 T7 T8 T9 T10 T15 T20 T25 T27 T30 T40 T45 torx bits Made in Germany but as often as one uses them I don't see the point unless you are totally anal and must have top of the line.
dlbehrns is offline   Reply With Quote
Old 12-13-2007, 05:32 PM   #14 (permalink)
adam01's Avatar
Date registered: Dec 2007
Vehicle: E320 CDi Avantgarde 2000 FACE LIFT MODEL
Originally Posted by gregs210 View Post
Okay, folks, clearly I was thinking of all of you while I was on vacation.
Attached is the PDF version of the MAF R&R process.
The end of it also includes a section on cleaning the MAF sensor.
Send your checks to World Vision.
And as always, take care and enjoy the ride!
Greg
hi Greg
you haven't by any chance a PDF version of the sump cover under the car
Adam
2000 X Reg MERCEDES-BENZ E320 CDi Avantgarde Tip
4 Doors, Automatic, Saloon, Diesel, Metallic Silver. * * * E320 CDi AVANTGARDE AUTO/
TIPTRONIC FACE LIFT MODEL* * *
adam01 is offline   Reply With Quote
Old 12-19-2007, 03:07 AM   #15 (permalink)
adam01's Avatar
Originally Posted by adam01 View Post
hi Greg
Adam
Old 01-21-2008, 07:44 AM   #16 (permalink)
Date registered: Jun 2007
Cleaned the MAF sensor insert rather than replacing unit which my dealer quoted as approximately $500.00 for the part. The sensor is not sold separately by the dealer. Followed the procedures of those who preceded me by using CRC MAF cleaner. Started after taking negative off of battery and continuing with procedure. It has been three days and the CEL has disappeared. It appears to run better; although, this may only be "in my head". Ordered insert for $139 from the internet in case this does not work. Eventually, I will have to replace the insert.
Thanks for info that saved me hundreds.
Entire procedure took less than 20 minutes. The need to utilize vise grips on the torx seurity screw took the most time. Searched the area of New Brunswick, NJ for torx security bit and was not able to find same.
19E96M90 is offline   Reply With Quote
Old 01-25-2008, 05:02 AM   #17 (permalink)
Vehicle: E320 4 Matic 2001
Usually this has to be done at about what milage. My 2001 e320 4 matic has 85000KM and the check engine light came on yesterday could this be the cause?
Hi Fi is offline   Reply With Quote
Old 01-25-2008, 08:39 AM   #18 (permalink)
gregs210's Avatar
Hey, Hi Fi.
There are dozens of sensors in the car, any one of which may go out of range and trigger the CEL. The ONLY way to know is to head to an Autozone (some other parts stores do this as well) and have the codes read. Don't rely on their diagnosis, just get the codes and either google them, search them on this site, or post them and we'll help you get to the bottom of it.
Also, don't ever ignore a CEL and hope it will take care of itself. While that can happen, it's exceedingly rare, and what is more likely to happen (depending on what triggered the CEL of course) is that you may end up damaging another component.
There is a deals sticky that provides the link for an excellent little code reader, $40 online but the shipping to Canada may be prohibitive. Reads codes, erases them, comes with a disc full of diagnostic codes and their meanings. Very handy to have around.
Greg
Old 01-25-2008, 09:21 AM   #19 (permalink)
Vehicle: 2001 E320 2WD
Send a message via MSN to Raylee177 Send a message via Yahoo to Raylee177
Gregs 210,
I do always appreciate your contribution in this forum. My MAF sensor cleaned in May 2007 just the way you instructed still works fine.
Raylee177 is offline   Reply With Quote
Old 01-25-2008, 10:31 AM   #20 (permalink)
Date registered: Jan 2008
Vehicle: W210 1996 E320 Exterior Smoked Silver, Interior Mushroom
the DIY does not apply to my car. The MAF sensor on 1996 E320 is quite diffirent, how is it cleaned?
W210 1996 E320 Exterior Smoked Silver, Interior Mushroom.
Bought Jan 2008 with 130K. Now 143 K miles as of 11/09/08.
texholdem is offline   Reply With Quote
DIY pictorial window regulator replacement ashman78 W210 E-Class 115 11-21-2008 10:59 PM
DIY MAF Cleaning slk230paul R170 SLK Class 17 08-14-2007 10:17 AM
anyone have diy-info on MAF cleaning? ProV1x W210 E-Class 2 11-30-2006 06:07 PM
Hello! and interest in pictorial DIY for window regulator? ashman78 W210 E-Class 5 08-31-2005 08:00 AM
