Old 08-28-2007, 09:20 PM   #11 (permalink)
Date registered: Jun 2006
I install the aftermarket alarm to open the door....
zzbchu is offline   Reply With Quote
Old 08-28-2007, 09:50 PM   #12 (permalink)
Date registered: Aug 2005
Vehicle: 2001 E320
Maybe it's time to replace the battery inside the remote. I found that MB remote uses battery pretty fast. Whenever, it stopped working on me, I replace the battery and it started to work.
cerritos is offline   Reply With Quote
Old 08-28-2007, 10:30 PM   #13 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
I've only removed aftermarket alarms. They're nothing but trouble.
Old 07-16-2008, 07:38 AM   #14 (permalink)
Date registered: Apr 2008
Vehicle: 1997 e320
to revive this ole thread- Is an aftermarket alarm a total "no no" on this car. I know the car is full of touchy sensors and doo hickies, but my IR sensor on my door is broken and the I have to lean over the hood to activate the one on the dash, which often takes a 20 tries before it finally opens..
p.s. I had an aftermarket alarm on a range rover before, it had a mind of its own, sort of how I imagine the mercedes to do.
Whalermax is offline   Reply With Quote
Old 07-16-2008, 08:06 AM   #15 (permalink)
How much does a new sensor cost?
Old 07-16-2008, 08:24 AM   #16 (permalink)
Vehicle: 1997 e320
I am not sure about one sensor cost, but I would imagine it would be similar to the cost of a whole viper system with remote start, 2 way communication, shock sensors and everything. Can you tell I work in the battlezone - downtown new orleans.
Do your systems work for farther than 6 feet, even when everything was new? This car never had any range to remote unlock/lock
Old 07-16-2008, 08:28 AM   #17 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
I heard from MB owners with aftermarket alarms, that they drain the battery in just few days. We had our MB parked armed for 5 weeks and they always started without a problem. My 97 E300d has sensor in the mirror, on the trunk lid and in driver door that got damaged by somebody trying to stick the key in it. I use mostly the one on the trunk. It is hit or miss. Sometimes the remote work, sometimes I have to use the blade key. No recognizable reason for any of this. Very often I can lock the car with the remote and need key to unlock. Very often it is opposite.
Kajtek1 is online now   Reply With Quote
Old 07-16-2008, 08:54 AM   #18 (permalink)
The IR remotes used in the older 210's are rather limited. I'd say that ten feet is about the maximum range that I can get.
I don't have the sensor in the door or trunk lid; only on the mirror. It would almost certainly work better if there were an additional sensor outside of the car. If your car were mine, I'd price that sensor. It's not a large part, but it is cosmetic so it might be somewhat expensive.
Since it goes in the place of the door cylinder, I would expect it to come out just as easily as that cylinder. Removing the door cylinder from my car is a five-minute job.
remote lock/unlock issues CAHEK W163 M-Class 6 11-02-2006 06:13 AM
remote key issues ggard W202 C-Class 0 07-02-2006 05:19 PM
Some issues on a W210 E 320 CDI T, heater and diesel smell matzhinrichs General Mercedes-Benz 1 12-28-2005 01:03 PM
Reliability issues: W210 2001-03 wagon ? rl1856 W210 E-Class 7 07-18-2005 12:17 PM
s320 Alarm Remote Control POOR Range I have to place the remote up to the class to get it to work. supersel W140 S-Class 16 02-06-2005 10:48 PM
