Old 07-06-2007, 06:33 AM   #1 (permalink)
donald1111's Avatar
Date registered: Jan 2007
Vehicle: '01 E320, '97 E420
Overheating in traffic
Hi~
My 97 E420 runs great, except for a new problem that just deleloped. While driving temp is in the proper range and does not fluctuate. When slowing down and being in traffic, temp climbs to almost the red zone. I checked the fan and it is running, antifreeze level is correct. Any ideas ? ? ?
thanks donald
donald1111 is offline   Reply With Quote
Old 07-06-2007, 07:26 AM   #2 (permalink)
E-Class Owner's Avatar
Vehicle: 1997 Mercedes Benz E420
Overheating is usually tied to lack of coolant, bad fan clutch, aux. cooling fans not running or a bad thermostat. When you say that the fan is running, which fan are you referring to?
E-Class Owner is offline   Reply With Quote
Old 07-06-2007, 07:31 AM   #3 (permalink)
donald1111's Avatar
Thanks for replying~
I believe that there is only one fan. Do you know if there are two speeds for that fan?
Old 07-06-2007, 07:59 AM   #4 (permalink)
slybydesignw210's Avatar
Vehicle: Pearl White 1994 Q45T
if its not the fans sounds more likely like the thermostat. I make sure what ever it is to fix ASAP, do to the fact that if your car keeps overheating you can loose your water pump. Ive had this happen before in my other car.
slybydesignw210 is offline   Reply With Quote
Old 07-06-2007, 08:01 AM   #5 (permalink)
donald1111's Avatar
Do you know if it easy to get to the thermostat on a 97 e420?
Old 07-06-2007, 08:08 AM   #6 (permalink)
'91 300CE's Avatar
Date registered: Jul 2006
Vehicle: 2000 C230K and 2002 ML320
Shouldn't there be 2 Aux fans in front of the radiator? These are Variable Speed Electric Fans that come on low speed when using A/C and/or when temps reach about 95c. They come on high speed when temps reach 105c.
My car has never reached or passed the 100c mark yet.
I do believe the viscous fan does have 2 speeds as well.
2000 C230K -- Travertine Beige Metallic
2002 ML320 -- Alabaster White
2002 ML320 -- Brilliant Silver - Dad's
1991 300CE -- Blue Black Metallic -- 129,000 miles -- Sold
1981 300SD -- Classic White -- 190,000 miles -- Sold
1977 240D -- Over 300k miles (Wrecked) -- My 1st car
'91 300CE is offline   Reply With Quote
Old 07-06-2007, 09:59 AM   #7 (permalink)
To be honest I am not sure where its at, but like the post above this reply states, if your missing the two aux fans in the front then that can be causing your issue. In my personaly experience, if it where anything besides the fan or thermostat then you would be having alot more issue pertaining to overheating. In my personal experience your simptoms sound much more like the thermostat based on how long its taking to overheat or get hot. In some cases the thermostat sits on the front end of the car, but MBs are different.
In Traffic Corkscrew R171 SLK Class 1 01-13-2007 03:23 AM
Overheating on idling or traffic! dtkw W126 S,SE,SEC,SEL,SD,SDL Class 19 12-29-2006 07:57 PM
How come - traffic down here 79percent G-Class 11 06-30-2006 06:48 PM
overheating in slow traffic rvenerac W124 E,CE,D,TD Class 4 12-22-2004 01:15 PM
Traffic Letter!!! kia W163 M-Class 8 04-30-2004 10:50 PM
