Old 06-26-2007, 06:35 PM   #11 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
FF means "end of codes."
Old 06-27-2007, 11:17 AM   #12 (permalink)
ohlord's Avatar
Vehicle: 99 e320 wagon,bmw,vw,mgb,mg midget,subaru wagon
Smile Ignore it
ff is a system value,the sun sensor doesn't affect the a/c to any detriment ,and after you properly fill the system the code may be gone anyway,or reset the system while in error mode.
Get a set of gauges to check and fill the system and if your not sure what you're doing get help,over filling can do more damage than under filled.Get the good gas not the stuff with the leak stop goop.Find the leak,be careful around the refrigerant,
it be bad!
ohlord
ohlord is online now   Reply With Quote
Old 06-27-2007, 03:45 PM   #13 (permalink)
illest's Avatar
Date registered: Sep 2006
Vehicle: 98 320
I got the kinda with the pressure guage on the bottle.
www.razoredgestudios.com
illest is online now   Reply With Quote
Old 06-27-2007, 03:57 PM   #14 (permalink)
Date registered: Jun 2007
Vehicle: 1997 E320
Originally Posted by jansa
well, after carefully following instructions I got some error codes out of my car
B231, B234,B235,B459, and also that website you gave me , they found out evaporator temperature sensor is malfunctioning, since it shows value 147F, and outside temp. is only 89F, I'll see what I do next I have no idea where this sensor is, thank you all, anyways
"260" is evap sensor...
Down South is offline   Reply With Quote
Old 06-27-2007, 04:20 PM   #15 (permalink)
Musikmann's Avatar
Lightbulb Sun sensor
As far as I know, the sun sensor only affects the fan speed, and speeds up the AC fan/blower when it detects direct sunlight.
please. input would be appreciated. mfprofile W208 CLK Class 5 02-27-2007 01:57 PM
Buying A New Car - Input Appreciated Bell R170 SLK Class 7 03-05-2006 08:05 AM
Input on this product would be appreciated MBZER Detailing and Car Care 2 01-24-2006 12:36 PM
Possible candidate? input appreciated.... Snibble W126 S,SE,SEC,SEL,SD,SDL Class 6 10-23-2004 06:20 AM
What is a fair price for this 2000 S430? Input greatly appreciated. CalBears92 W220 S-Class 2 08-06-2003 08:03 AM
