2000 e320 fuse boxes location??? - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 06-15-2007, 05:59 AM   #1 (permalink)
mbnz230's Avatar
Date registered: Jun 2004
Vehicle: 2000 e320 + 1996 s320 + 2004 clk500
i know there's the main fuse box in the engine compartment. but i want to reset the radio and its fuse #4 i believe and its got a star next to it. so its located under the rear seats? but i cant seem to find it. pics would be great. not sure if the fuse are located at the same location as the pre 2000. thanks.
mbnz230 is offline   Reply With Quote
Old 06-15-2007, 08:28 AM   #2 (permalink)
Vehicle: 2001 E320 2WD, 2012 E350 BlueTec, 2008 BMW 528i
Send a message via MSN to Raylee177 Send a message via Yahoo to Raylee177
Under rear seat. Just pull out the seat and you will see it there.
Raylee177 is online now   Reply With Quote
Old 06-15-2007, 08:35 AM   #3 (permalink)
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
There is also a fuse block on the left end of the dash, open the door and it's the vertical triangular shaped panel. It's pretty stiff to get out but it just has press-fit inserts. I don't know if there is a radio fuse in that one, I'm just mentioning that this is another fuse location.
While we're on the subject, anyone know a specific location for a fusible link in the charging circuit?
Take care and enjoy the ride,
Greg
Check Codes is offline   Reply With Quote
Old 06-15-2007, 10:02 AM   #4 (permalink)
mbnz230's Avatar
thanks guys, i just fixed my problem, i had a cd changer problem, loaded the cd magazine with cd's and when press cd it reads magazine empty. so i took the cd changer apart and mess around a little and put it back together and its working now. anyone know where the battery is, is it also under the rear seats? cause i cant seem to find it in the trunk or engine compartment. how do you pull the rear seats out?
Old 06-15-2007, 10:20 AM   #5 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Feel around the base of the seat cusion, near the front corners. There is a small lever which must be pulled up on each side. The radio fuse is indeed under there.
Old 06-15-2007, 10:29 AM   #6 (permalink)
If you look in the DIY sticky for this forum you'll see a post I did about replacing the battery, it has pictures for the seat latches, etc.
That much-ignored search function often brings great results.
Greg
Old 07-15-2009, 11:09 AM   #7 (permalink)
Date registered: Nov 2006
Vehicle: 500 SEL 380Sl
Having the same problem. One day the radio went dead for no apparent reason. The CD changer has been reading empty. Took it out and put it back in. Radio still does not work. The fuse under the hood looks and tests good. Is there another fuse? E320 Wagon 1998
mrrefund is offline   Reply With Quote
Old 07-15-2009, 12:40 PM   #8 (permalink)
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
One
on the back of the radio. Pull it and check it.
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
ohlord
"Follow Peace,center Life"
Old 04-19-2011, 07:29 AM   #9 (permalink)
Date registered: Apr 2011
window switch porblem..
Hello guys, part no 21082139517C45
I got a problem with my cars window switch it's E320 98.
The switch was a little stick it won't move smoothly so I took it out and cleaned it with a wet napkin and had it back in the car but it didnt work at all.
I'm actually dont know what should to be done.
Is it because the fuse or the hole thing I mean the switches?
And yesterday I tried to unlock the doors and the alarm went on.
I'm really stock with it.
Help me out guys.
Abdul-benz is offline   Reply With Quote
Old 04-19-2011, 08:29 AM   #10 (permalink)
Musikmann's Avatar
Vehicle: 2001 E320 - Brilliant Silver/Ash: 99,000+
Abdul, please start a new thread and be more specific. For example: Are you talking about one of the window switches on the center console? When you set off the alarm did you unlock the doors with the remote or with the switch on the dashboard?
Bookmarks
2000 ML 320 Lighter Fuse Blown | Which fuse do I replace? Patkar g_patkar W163 M-Class 6 09-21-2009 06:28 PM
Fuse location callibenz W203 C-Class 4 12-28-2008 10:10 AM
Fuse box location? Corey R170 SLK Class 2 07-09-2006 05:08 PM
Location of the cps in a 2000 E320! m-benz20708 W210 E-Class 5 06-10-2006 09:07 AM
Newbie Question: Where are the fuse boxes on the '85 190E Benzluv W201 190 Class 1 08-28-2002 10:10 AM
