Old 06-01-2007, 07:54 PM   #1 (permalink)
mr diesel's Avatar
Date registered: Jul 2004
Vehicle: 1997 E300D
Send a message via AIM to mr diesel
Angry fuel filter replacement
well i thought it was easy ,,,it will not start now, i had it running a bit then it stalled its self out but i hear a loud noise at idle but if i rev it up a little bit it is gone, so what is my next step??? does this have a primer like my W123 it sounds like i have air in the system
1997 E300D
mr diesel is offline   Reply With Quote
Old 06-02-2007, 03:15 AM   #2 (permalink)
Vehicle: W210 E300TD
Check you have correctly replaced the o-rings around the filter housing.
You should also have filled the filter to the brim with diesel before you screwed it back on.
It is self priming, you'll have to keep turning it over. Make sure you give the starter motor a rest every minute or two.
Parrot of Doom is offline   Reply With Quote
Old 06-02-2007, 06:07 AM   #3 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
As said above, you MUST replace the O rings when you change the filter. They often do not come with the filter like you would expect.
sokoloff is offline   Reply With Quote
Old 06-02-2007, 08:32 AM   #4 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
In addition, it's very easy to miss the pre-filter o-ring. Unless you're looking for it, you may not even realize that there's one there; but your new filter will not have it installed and it doesn't come with it.
The big filter did come with the o-rings the last time I changed it.
Old 06-02-2007, 09:35 AM   #5 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
Pre-filling diesel filter is not recommended, since contamination might screw injectors.
Just push gas pedal to the floor and keep cranking. See the other thread in this section about fuel run out.
Kajtek1 is online now   Reply With Quote
Old 06-02-2007, 11:02 AM   #6 (permalink)
Unlikely. Not something I've ever heard of. But if it does bother the OP, either refill it with clean diesel from a can, or buy some injector cleaner and fill it with that.
And theres no need to push the pedal to the floor since the accelerator control is electronic.
Old 06-03-2007, 05:54 PM   #7 (permalink)
mr diesel's Avatar
Vehicle: 1997 E300D
Cool
thank you to all ,that is right i did not have the o ring installed ,but now i get a clang intermintely at idle i hope i did no damage trying to start it
Fuel filter replacement surfjones W126 S,SE,SEC,SEL,SD,SDL Class 13 10-10-2007 09:32 PM
Fuel filter replacement BajaCat W163 M-Class 5 05-16-2007 02:50 PM
Fuel Filter Replacement icedtrip R/C107 SL/SLC Class 0 12-24-2006 07:07 PM
Argh - fuel filter replacement rowingdude W124 E,CE,D,TD Class 0 03-27-2006 06:45 PM
Fuel Filter Replacement? G-Benz W163 M-Class 5 05-06-2003 12:26 PM
