Old 05-25-2007, 12:06 PM   #1 (permalink)
Date registered: Nov 2003
Can't remove rear license plate screws!
I am not having any success removing the rear license plate screws. After using some WD40, all four just turn continuously. I peeled back the trunk liner and see a female end which keeps turning and I'm unable to free the two.
Any suggestions?
Thanks!
E430_4Matic is offline   Reply With Quote
Old 05-25-2007, 01:22 PM   #2 (permalink)
Mark Cummins's Avatar
Vehicle: W211/W210wagon/W209
Grab them with Vise grips and then drill out the old nut certs and replace them
Mark Cummins is online now   Reply With Quote
Old 05-25-2007, 07:40 PM   #3 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
I had the problem with those rivets, that spin in the hole as well. It the screw is not too corroded, inserting the good screw driver in the screw and tilting the handle while turning it did the trick for me. By tilting the rivet you increase the friction between the rivet and the body panel.
Question how to protect it for the future. I used thread locker.
Kajtek1 is offline   Reply With Quote
Old 05-26-2007, 01:25 PM   #4 (permalink)
Date registered: Apr 2007
Vehicle: 97 E320
I had the same issue. I unsnapped the trunk lining and held the rivets with a vise while I unscrewed them from the outside. It worked for me. I have to say that it was a little tricky. Good luck.
Michael
1997 E320
1985 380 SE (RIP)
Ternati2000 is offline   Reply With Quote
Old 05-26-2007, 07:04 PM   #5 (permalink)
~BANNED~
Designo_E320's Avatar
Vehicle: 2000 E320 Designo
Just pull on the license plate (outward) while you turn the screws. Should work.
Designo_E320 is offline   Reply With Quote
Old 05-26-2007, 08:03 PM   #6 (permalink)
ozcan's Avatar
Date registered: May 2003
Vehicle: 00 ML430 & 01 E430 4matic Both Silver+Black
Remove the inner cover liner and hold the female bolt with a pair of players (vice) to prevent them turning while unscrewing form outside. This should do.
E430 2001 4Matic Silver All factory options + 30% tint
"xenon, parktronic, navigation, voice recognition, rain sensor, multicontour seats, vantilated seats, rear curtain ect"
OPTION LIST STICKER
ML430 2000 Silver MODS: Bi-Xenon, Chrome Grill
Previous cars: E320 2000 Nav, xenon, voice - 300E 1991 - 190E 1985 - 190D 1984 - 200SE 1976
MY SIMPLE E430 & ML430 WEB
ozcan is offline   Reply With Quote
Old 06-26-2007, 10:20 PM   #7 (permalink)
mrhappy71's Avatar
Vehicle: mercedes e320 2000
What can i use to remove the black plastic holders keeping the liner intact without damaging them
thanks
mrhappy71 is offline   Reply With Quote
Old 06-27-2007, 01:14 PM   #8 (permalink)
Vehicle: 97 E320
thanks
I used scissors to slid under both sides of the black cap. I gently pryed up until they popped out of the holder. When you put them back make sure they clip correctly. Test it out and you will get the hang of it. Good luck.
Michael
license plate mouting screws & inserts bass1175 W140 S-Class 10 04-15-2007 05:28 AM
License plate screws on 82 300D kaminskc W123 E,CE,D,CD,TD,TE Class 1 12-10-2006 07:02 AM
License Plate holder screws/bolts - Sunroof ? NewMBOwner W201 190E, D-Class 7 04-22-2005 10:10 AM
Remove front license plate mount? dulinor R170 SLK Class 2 03-03-2005 06:27 PM
License Plate Screws k6lw R170 SLK Class 5 01-01-2003 04:04 PM
