Old 05-21-2007, 03:06 PM   #1 (permalink)
Date registered: Sep 2006
Red face P0130 Sensor Circuit Malfunction.
Hi all,
I need some help how to fix the trouble code P0130. I have cleared the code twice. Is it ok for driving or I have to fix the Oxygen Sensor? (Bank 1 Sensor 1)
Thanks for your help...
okiloveu is offline   Reply With Quote
Old 05-21-2007, 03:41 PM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hey, okiloveu.
There is no repair for the O2 sensor, just replacement. Best prices are on-line but they're still not cheap.
I would not let it go, with the sensor out of range you're possibly suffering a mileage loss, likely emitting more pollutants than you should and it's very probable that you'll damage something else, like another O2 sensor or a cat.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 05-21-2007, 05:53 PM   #3 (permalink)
Gray,
Do you know where it's located? (Bank 1 sensor 1)? is it easy to replace?
Thanks.
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction cocktailsfirst R170 SLK Class 5 03-18-2008 12:57 PM
1998 mercedes e320 P0715 input/turbine speed Sensor malfunction raylui88 W210 E-Class 5 01-13-2008 04:11 PM
Light Sensor, ESP, & Telaid Malfunction - but nothing appear wrong... boiler81 W203 C-Class 2 04-27-2007 07:11 PM
P0130 code on 96 s500! can someone help? 96s500 W140 S-Class 2 01-20-2007 12:41 PM
Error B1234 (Sun Sensor Malfunction) E430_4Matic W210 E-Class 0 06-10-2006 07:18 AM
