» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 05-23-2007, 10:56 PM   #11 (permalink)
tonyr69's Avatar
Date registered: Apr 2007
Vehicle: Mercedes E320 2001
Originally Posted by LorenzoBenzo
Whew, I just installed the new pieces. Not as easy as I anticipated because I couldn't get the screw hole to line up. After playing around with it, I finally got it to fit.
Can you post a pic?
Tony
tonyr69 is offline   Reply With Quote
Old 05-23-2007, 11:27 PM   #12 (permalink)
Date registered: Feb 2007
Vehicle: 2000 E320
Originally Posted by tonyr69
Can you post a pic?
Tony
I'll try to post pics this weekend.
Just to clarify, most of you would be able to do this with no issues at all. I'm just such a non-DIY guy. I make the easiest things seem so difficult. What should've taken 5-10 minutes to do took me 30-45 minutes. It's always this way for me...
LorenzoBenzo is offline   Reply With Quote
Old 06-30-2007, 10:10 AM   #13 (permalink)
sailswish's Avatar
Vehicle: 2002 E320 Silver Wagon
Windshield Trim Question
I would like to replace the plastic rubbery trim pieces which are located in the lower portion of the windshield under the wiper. It's the transition piece where the hood starts. Mine is rather sun damaged and starting to crack at the edges. A proper name for this and a parts store online would be much appreciated.
2002 E320 Silver Wagon.
sailswish is offline   Reply With Quote
Old 06-30-2007, 10:14 AM   #14 (permalink)
Musikmann's Avatar
I have seen a used Benz on a lot that was doing the same thing, and it looks really nasty. Try: Mercedes Benz Parts, Mercedes Parts, Accessories and describe it just like you just did here. If they don't have it, call them and ask for Ron (mention Benzworld). He should know where you can get that. Good Luck!
Old 07-01-2007, 12:55 AM   #15 (permalink)
Vehicle: 2000 E320
$40 total for both sides. I just replaced mine. Check out the below thread from a little while back.
http://www.benzworld.org/forums/w210...t=lorenzobenzo
Old 07-01-2007, 03:18 AM   #16 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Thanks for posting that Lorenzo here's the info. again..
Its' all one piece, & don't worry it's easy to install & cheap . Here are the part numbers:
210.831.0958 - $20.00
210.831.1058 - $20.00
Goodluck,
JOE55
JOE55 is offline   Reply With Quote
Old 07-01-2007, 11:30 AM   #17 (permalink)
meooem1's Avatar
Date registered: Nov 2006
Vehicle: 99 e320 wagon gold/tan 105K miles
did you get those parts at the dealer, or did you order online? if anyone has found them online can you hook us up with the link....thanks
meooem1 is offline   Reply With Quote
Old 07-01-2007, 01:51 PM   #18 (permalink)
JOE55's Avatar
Vehicle: E55 ///AMG
special order by dealer
Old 07-01-2007, 04:45 PM   #19 (permalink)
Vehicle: 2001 E320 2WD
Send a message via MSN to Raylee177 Send a message via Yahoo to Raylee177
Don't feel bad practically 100% of our year cars will have same problem. Lucky that it is easy to replace and not that expensive. I had mine replaced also.
Raylee177 is offline   Reply With Quote
Old 07-01-2007, 04:50 PM   #20 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
I guess you didn't get around to posting a picture. I'm trying to figure out what part you're talking about. I have a large plastic pan-like piece at the windshield base; is this it?
Why no tint strip on windshield? ARIDAN W164 M-Class 0 12-04-2006 05:36 AM
Tail Lamp Lens Rubber Strip mkyang W126 S,SE,SEC,SEL,SD,SDL Class 1 02-23-2006 07:34 PM
How to remove rubber strip above sills? w5yk G-Class 3 09-12-2005 12:56 PM
Rubber on rear bumper "impact strip" came off... How to reattach??? jtoma878 W123 E,CE,D,CD,TD,TE Class 4 01-31-2005 02:47 PM
help on fixing the rubber black strip of the front bumper... MercedeSChink W163 M-Class 2 05-11-2004 05:55 AM
