Old 05-06-2007, 06:56 PM   #1 (permalink)
Vehicle: Mercedes W210 E320 wagon
Send a message via ICQ to Bansai
P1453 AIR relay module AIR relay module in passenger-side fuse and relay module box ?
I've this error today. What it could be?
P1453 AIR relay module AIR relay module in passenger-side fuse and relay module box.
Bansai is offline   Reply With Quote
Old 05-07-2007, 05:00 AM   #2 (permalink)
Just fixed. It was bad contact in pink connector, in relays module box (where ESU is located).
Old 05-07-2007, 08:24 AM   #3 (permalink)
slybydesignw210's Avatar
Date registered: Jan 2007
Vehicle: Pearl White 1994 Q45T
how much u payed for the fix?
slybydesignw210 is offline   Reply With Quote
Old 05-07-2007, 09:44 AM   #4 (permalink)
Red face
I payed nothing. Yesterday I fixed A/C leak (replaced one hose and dryer) and unscrewed and disconnected this unit (I had to remove water collector and wiper blade with motor). After, when I reinstall all staff back then just forget to connect small connector in relays box... Found lost connector in the Morning.
Opps...
Old 05-07-2007, 10:07 AM   #5 (permalink)
I see you got a nice seat on the "Train" LOLOLOLOLOL welcome......cool I am always interested in hearing cool DIY fixes, because it helps me do things myself when I have issues. Just wish I had a shop I could work at, I live in an apartment complex, so no car washing let alone an oil change, but I get away with dry washes, waxing, claying...
E-Box Fan Fuse or Relay...Where is it? M_city W163 M-Class 4 03-26-2007 08:22 PM
Ticking relay under the dash on passenger side. DrWorm W126 S,SE,SEC,SEL,SD,SDL Class 6 07-28-2006 02:33 PM
K40 Relay Module upstate engineer R170 SLK Class 2 10-26-2005 08:44 PM
Ignition module or Fuel pump relay? FatTony W126 S,SE,SEC,SEL,SD,SDL Class 1 08-30-2005 05:57 AM
Air Management Relay rorlan R171 SLK Class 8 06-16-2005 05:10 AM
