» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 04-18-2007, 02:56 PM   #21 (permalink)
Date registered: Dec 2006
Vehicle: 1997 E320, 1997 S320
slybydesignw210, his car vibrates only at high speeds. that seems to me more related to proper wheel balance and bad tires, that;s why i thought it;s not the motor mounts. but i;m not a professional mechanic, that's just what i thought.
personally i would do the shocks, lower ball joints and bushings first before doing anything else.
tirona is offline   Reply With Quote
Old 04-18-2007, 03:01 PM   #22 (permalink)
RSPINAJR's Avatar
Date registered: Apr 2007
Vehicle: 1997 E420 18" AMG Monoblocks
It does do it at surface road speeds as well although not all the time. sometimes its perfect. at idle in drive or not the car is as smooth as can be its only as I start moving when it happens
RSPINAJR is offline   Reply With Quote
Old 04-18-2007, 03:36 PM   #23 (permalink)
ruBENZ_00E55's Avatar
Date registered: Mar 2006
Vehicle: 2000 E55 AMG
Originally Posted by RSPINAJR
I found one - two germans off the boat...
But, you need an automobile mechanic, not a boat mechanic. Sorry, I couldn't resist.
ruBENZ_00E55 is offline   Reply With Quote
Old 04-18-2007, 03:38 PM   #24 (permalink)
Originally Posted by tirona
...personally i would do the shocks, lower ball joints and bushings first before doing anything else.
I agree.
Old 04-18-2007, 03:42 PM   #25 (permalink)
loubapache's Avatar
Date registered: Feb 2007
Vehicle: 03 E320 4M Wagon & 97 E320
I'll bet my $50 on the swaybar bushing/brakets/end connectors for the noise. It is easy to check and you may not need to lift the car. Just grab it and shake it to see if it is loose.
loubapache is offline   Reply With Quote
Old 04-18-2007, 07:50 PM   #26 (permalink)
Date registered: Nov 2006
Vehicle: Oo == oO 98 E320
"Car wandering on highway" & creaking both sound to me like the lower control arm bushings.
'87 300E: sold after 11years @ 230k & still on the road somewhere in rural Tennessee.
'94 C220 with 93k totalled 10/06 by hit & run broadsiding monster truck: not a scratch or bruise for me
johnamoss is offline   Reply With Quote
Old 04-19-2007, 08:04 AM   #27 (permalink)
RSPINAJR's Avatar
So the CEL went out on my way back from work last night I'll check the swaybar bushing/brackets/end connectors tonight. Thanks again everyone!
Old 04-19-2007, 08:11 AM   #28 (permalink)
slybydesign's Avatar
Date registered: Jan 2007
Vehicle: My Two Left Feet
bushing/brackets/end connector - I 100% agree with that. In another topic question stemming from this thread, does any suggest updating changing motor mounts in general, thats probly the way I should have expressed my question.
slybydesign is offline   Reply With Quote
Old 04-19-2007, 09:31 AM   #29 (permalink)
in that order? any suggestions on shocks? Koni?
from what i have read in this great website, a lot of people have been satisfied with bilsteins. i think they are around $80-90 a piece. it;s suggested to change the shocks every 10 years/100k miles, but to tell you the truth, i haven't changed mine yet on my 97e320 with 135xxx miles because it rides and handles fine. it will probably be sometime in the near future.
Vibrations Judas W140 S-Class 6 11-30-2005 06:05 AM
Vibrations ack W163 M-Class 29 10-14-2005 09:17 AM
Bad Vibrations 4x4rancher G-Class 8 10-03-2005 02:30 PM
Bad vibrations in reverse... any ideas? pterion R170 SLK Class 12 09-09-2005 11:08 AM
Vibrations..... CustomSLKIOM R170 SLK Class 0 02-27-2003 06:54 AM
