» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 03-17-2008, 05:26 PM   #21 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Originally Posted by keyhole
Hope this isn't a dumb question, gregs - but why can't I just turn the ignition switch to pos 1 ?
Hey, Keyhole. I just saw this; my apologies for not answering sooner. I don't know if it's in the WIS or what, but my default understanding is that if the battery is being disconnected, the key should be not only off but in your pocket. Just having it in the ignition energizes some circuits and with it in POS 1 lots of stuff is hot, that would likely overload a 9V battery plugged into the cigarette lighter, with all sorts of potentially ugly results ... the least of which is that it would drain flat and you'd end up resetting everything.
My default position when I post tips and DIYs on here is to post things that (1) work and (2) are generally safe (both from a personal as well as a car standpoint) if done as suggested. They may not necessarily be the easiest or shortest or fastest or (fill-in-the-blank), but they fit that general framework. If you want to go test the key-on-cigarette-lighter-device-plugged-in and post your results, let us know. Myself, I'm not excited about the possible downside.
Originally Posted by texholdem
it may sound trivial but I suppose it would also work for saving the settings if using an AC-DC converter with 12V output instead of the 9V-Monoblock too, right?
Hi, Tex. With a couple of caveats, I don't know any reason that shouldn't work. I know I wouldn't try an automatic battery charger, for example, as those look for load, resistance, etc. and vary output; I don't even want to guess what those might do when the battery was disconnected. Also, when the battery is disconnected there is an "open" loop in the circuitry; a 9V battery isn't enough to do any damage to anything (even if you let the positive cable hit the frame), depending on the current available a 12V output conceivably might. Again, I can't think of any specific reason it shouldn't work ... but refer to my default position above.
Gents, thanks for the thoughts and, as always,
Take care and enjoy the ride.
Greg
If we ever forget that we are one nation under God, then we will be a nation gone under.
Ronald Reagan
Old 01-02-2009, 04:08 PM   #22 (permalink)
Date registered: Aug 2005
Vehicle: 2002 e55, 2005 Boxster, 2000 Corvette, et al.
Hate to bump an old thread, as I'm probably missing something simple.
How do you use the latch? I've tried pushing on it and pulling on it. Looking at it, it even seems like it could slide to the side. I don't want to break anything, so any assistance is welcome.
I really want to get this e55 back on the road. It's been sitting in a nice climate controlled garage for two years now, but it deserves to see the road.
SamirD is offline   Reply With Quote
Old 01-02-2009, 04:22 PM   #23 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
By "latch" do you mean the latch that holds the rear seat onto the car?
If so, reach in, find the lever, and pull straight up.
Old 01-02-2009, 04:34 PM   #24 (permalink)
Thank you, that's exactly the latch I was posting about. I should have been more clear.
I will try pulling straight up towards the roof.
Old 01-02-2009, 04:50 PM   #25 (permalink)
Thank you! That did the trick. I'm usually so much more mechanically inclined. Battery is out and ready for replacement.
Old 01-02-2009, 04:55 PM   #26 (permalink)
Don't feel bad. I had to look at the owner's manual the first time because I couldn't figure it out either.
Old 01-02-2009, 04:59 PM   #27 (permalink)
And if anyone is interested, the torque required to take off the battery hold down clamp is 20ft/lbs. I plan to tighten it back to the same spec.
Old 01-02-2009, 10:13 PM   #28 (permalink)
It was in the owner's manual?!? Now I feel like a real idiot. Yep, right there on page 297.
Old 07-18-2009, 07:11 AM   #29 (permalink)
Date registered: Dec 2008
:QUOTE=gregs210;2328708]It's been a while coming, but here is the post for how to change your battery yourself. With pictures, of course.
This includes a setup that will help you avoid having to reset everything, which was probably the more enjoyable part of this exercise for me. If you don't want to make it yourself, I'll sell you one for $15 including the 9V battery (a new alkaline, not the one from my smoke detector!).
Take care and -- as always -- enjoy the ride,
Greg[/quote]
brilliant . thanks for the time to post this piece of info most helpful..:
dave e320 is offline   Reply With Quote
Old 07-20-2009, 06:22 PM   #30 (permalink)
Date registered: Apr 2006
Vehicle: 2000 E320
Cool Why not just jump from another car battery?
Why not just use jumper cables from another car to hold the voltage while changing the battery? Of course, no key in the ignition switch while doing this. I have not tryed this but may someday when needed if there is not a known problem.
jlbarnes is offline   Reply With Quote
Advice on DIY vs. Non DIY Repair Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 10 08-30-2008 11:58 PM
replace rear subframe mounts - DIY or not DIY? philthompson W126 S,SE,SEC,SEL,SD,SDL Class 1 02-02-2007 07:40 AM
losing coolant need help ?? amgstyle R170 SLK Class 13 01-12-2007 07:16 AM
Losing Interest? nobby R/C107 SL/SLC Class 16 09-24-2006 09:48 AM
i think i'm losing it.... Russ250CE Vintage Mercedes-Benz 3 08-22-2004 07:09 PM
