» Site Navigation
» Other Sites
Old 04-07-2007, 02:24 PM   #1 (permalink)
Date registered: Oct 2006
climate control
Hi
I have a 1996 230E, I have two problems, firstly the door mirrors dont work, is there a fuse for them somewhere?
secondly, the divertor flaps on my heating system dont work properly, I tested the acutaters with a mityvac and they are all ok.
When I applied vacum to the valve block with the twelve vacum pipes, it wont hold a vacum, (should it?)
even when I disconnect the pipes from the block and remove the body of the block it wont hold vacum.
It sems that as soon as I start the car "all" of the accuater pods actavite.
I have air coming out of all vents (except the windscreen defog) no matter where the display points.
walkerfamily is offline   Reply With Quote
Climate Control bullyben W201 190E, D-Class 2 12-15-2006 06:58 PM
climate control? kickboxer W126 S,SE,SEC,SEL,SD,SDL Class 0 11-08-2006 03:03 PM
Climate control Jippi W201 190E, D-Class 2 05-10-2006 09:30 AM
cruise control vs. climate control CCarlisle W123 E,CE,D,CD,TD,TE Class 0 11-04-2005 09:51 PM
Climate Control Guest (MBNZ) W140 S-Class 2 01-02-2002 05:27 PM
