Old 04-06-2007, 09:53 AM   #1 (permalink)
Date registered: Apr 2007
Climate control not lighting up!
Hi,
A little problem with my 98 E320W. When I turn on the lights for the car the climate control unit does not light up. It still works fine, just doesn't light up? Possible causes? A bulb gone possibly? If so, how do I go about repairing this and removing the unit?
Thanks!
topgun129 is offline   Reply With Quote
Old 04-12-2007, 07:45 PM   #2 (permalink)
Vehicle: E 320; 1997
I have replaced the bulb twice attempting to solve the same problem? I have learned that I might need to get the fuses checked.
97 E320
jameclark is offline   Reply With Quote
Old 04-13-2007, 07:23 AM   #3 (permalink)
Date registered: Jan 2007
Vehicle: 2005 S500 4matic Sport Designo
get the removal tools on ebay, search "mercedes radio tool"
get the bulb at the dealer.
slide tools into the little slots at the bottom of the "auto" buttons.
slide unit out. On the bottom you will see a little white insert. rotate counterclockwise and let it fall out in your hand. Replace the bulb and reassemble.
OliverK is online now   Reply With Quote
Old 04-13-2007, 07:34 AM   #4 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
The first thing to know is that the climate control light doesn't come on directly after the head lights are turned on. The processor inside the climate control responds to information or data from the car. If the headlights are turned on, it can take a few minutes for the climate control to turn it's light on. If there is a fault in the data or in the climate control unit, it may not know that the lights are on and then not turn the light on. In that case, the unit may have to be replaced.
The first thing to do is to replace the bulb as mentioned before. Then if that doesn't work, find a friend who has an E-Class to try your controler in to see if it operates normally. Then if it does the same thing in another car, find a different one on ebay or salvage yard. They sell for about $100 for a used one.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 04-13-2007, 01:43 PM   #5 (permalink)
flw210's Avatar
Date registered: Feb 2007
Vehicle: 1998 Mercedes E320
Send a message via Yahoo to flw210
Here are some pics....
Flat side on the keys goes outward towards the doors.
Take good care of your car and it will take good care of you.
flw210 is offline   Reply With Quote
Strange Climate Control lighting issue twalton W126 S,SE,SEC,SEL,SD,SDL Class 3 08-08-2007 02:40 PM
Climate control Lighting daimler560 W201 190E, D-Class 7 12-22-2006 05:28 AM
Climate control Lighting mafic W124 E,CE,D,TD Class 1 12-18-2006 11:56 PM
Climate Control Lighting? AU_420SEL W126 S,SE,SEC,SEL,SD,SDL Class 3 11-15-2005 06:30 AM
Bulb/Lighting for climate controls...where is it? Help! AFARR W201 190E, D-Class 1 06-18-2005 09:15 PM
