Old 04-04-2007, 05:38 PM   #1 (permalink)
Date registered: Mar 2007
glow plug light flickers off and on.
I did a seach and couldn't find anything. Car starts and runs fine, but on acceleration from a stop the glow plug light flickers and comes on and off, then once you are up to speed it stays off. What do you think it is? It is a 96 e300 diesel. 87000 miles. I am the third owner and just picked it up three weeks ago, so I don't know the maintenance history.
draaronr is offline   Reply With Quote
Old 04-04-2007, 08:55 PM   #2 (permalink)
Date registered: Nov 2006
I had the same experience. I checked the plug at the glow plug relay on the driver's side fender under the hood. It was loose. I plugged it in snuggly and the problem was gone.
Or, the car is trying to tell you that a glow plug is bad.
To test each glow plug I pull the plug mentioned above from the relay and test each lead in the plug (6) with either a test light, or a continuity tester, to ground. Any one that will not ground through the glow plug is bad.
I hope it's a loose relay plug.
If you have to replace a glow plug and you are a DIY don't let the removal of the intake manifold to gain access to the glow plugs intimidate you. 6mm allen socket, T40 torks socket, 2 vacuum lines, 2 electrical plugs. It will take you 30 to 40 minutes to remove the first time. It takes me 20 minutes the second time.
I had to remove the intake (twice) when I converted my '96 E300D to run on vegetable oil.
GregMN is offline   Reply With Quote
Old 04-04-2007, 09:17 PM   #3 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Just don't break any of them off in the head.
Old 04-05-2007, 05:45 AM   #4 (permalink)
do you have a pic of the relay?
Old 04-05-2007, 06:21 PM   #5 (permalink)
Attached are photos. The relay has a white label on it.
The first shows the relay to the right of the ABS unit and to the rear of the washer fluid bottles.
The second shows the relay with the cover removed and the 6 connector plug to the glow plugs unplugged.
Old 04-06-2007, 07:12 PM   #6 (permalink)
that's awesome I will try it in the am, thanks a lot
Old 04-07-2007, 06:17 AM   #7 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
Take an ohm meter to the glow plug connector that plugs into the relay and measure each glow plug's resistance. Good plugs will read about 0.6 ohms cold.
Len
sokoloff is offline   Reply With Quote
glow plug light and starting mercwagon W123 E,CE,D,CD,TD,TE Class 4 10-26-2006 06:44 AM
glow plug light only comes on when 5 pin plug is disconnected from relay JLincoln W123 E,CE,D,CD,TD,TE Class 5 11-20-2005 05:58 PM
Glow plug light johnny123 W123 E,CE,D,CD,TD,TE Class 18 06-21-2005 11:32 AM
Glow plug light amolak V-Class 1 03-01-2005 02:12 AM
Glow Plug Light Tomo G-Class 2 12-27-2001 07:18 AM
