Old 04-04-2007, 04:14 PM   #1 (permalink)
Date registered: Dec 2006
Help!! front light turned red
Hi I have E240 '2000 with xenon white front lamps. yesterday when I turned the lights on, I noticed that the right front light is turning red slowly, any idea what is the problem?
Thanks in advance
InXWorld is offline   Reply With Quote
Old 04-04-2007, 04:46 PM   #2 (permalink)
raymond-'s Avatar
Date registered: Jan 2004
swap the bulbs to the other side. if red shifts to the driver side, then you have
a bulb which is undergoing red dwarf syndrom, ie dying .
if it doesn't and red shift is still on pax side, then you need to focus on the ballast/
ignitor. you can try swapping that, and if the red shifts, this is an indication of a
dying ballast.
oh....if it turns out to be a bulb replacement needed, buy two at the same time,
from same lot# to ensure as much as possible, same tint/color/ºK. if you don't
buy same model/make, color may be a bit off.
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
Old 04-04-2007, 05:10 PM   #3 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Looks like your lights going to die & doesn't look like a 4300K stock also, did you happen to touch the bulb when you are replacing it before?
JOE55 is offline   Reply With Quote
Old 12-09-2007, 09:07 PM   #4 (permalink)
Date registered: Mar 2007
Vehicle: 1990 500SE
light changing color.
Thanks in advance
I to have a similar situation with my lights. My veh. is a 97 E320 with the Xenon lights. One lights is a bright white , the other has a bit of pink/red in it and according to post may be dying out.
I am not famliar with these Xenon lights as I have never had them on any of my past veh's.Are these bulbs simply a unplug and remove and then replace or is there more to it ? Besides the dealership cab you buy the bulbs at car part stores such as NAPA etc.
108Benz is offline   Reply With Quote
the squiggly thing that glows red when the car is turned on... iNeon W123 E,CE,D,CD,TD,TE Class 16 02-05-2005 12:11 PM
Check Engine Light turned itself off bluefrosch R170 SLK Class 0 01-16-2004 01:04 PM
Aux light switch turned on my brake light???? 4benzes W163 M-Class 5 11-18-2002 04:01 AM
BAS/ESP light turned on briefly rogerl W163 M-Class 8 10-02-2002 07:40 PM
My 320 ESP/ASB light turned on.... Jeffrey R170 SLK Class 2 10-26-2001 12:36 PM
