Old 04-04-2007, 08:38 AM   #1 (permalink)
Date registered: Jan 2006
00 E320 Intermittent Starting Problem
Almost always, this happens after the car has warmed up and then stopped for a short while and restarted. When you go to restart, it cranks and cranks. In fact, even after you turn the key back off the crank position, it keeps cranking until you pull the key all the way out.
Seems like it might be a key problem. Took it in to a very good local independent. There were no stored codes. He monitored fuel pressure, drive all over the place and couldn't repeat the problem. Of course I got it to repeat several times the day I got it back.
Key problem? CPS? MAF? Seems like if it was CPS or MAF, it wouldn't keep cranking.
youngwerth is offline   Reply With Quote
Old 04-04-2007, 10:37 AM   #2 (permalink)
Musikmann's Avatar
I think both a CPS and a MAF error will cause the car to store codes.
Intermittent starting problem -E240 nikko W210 E-Class 3 06-15-2007 06:14 PM
help 99 E320 intermittent starting MELLOBENZ W210 E-Class 2 12-06-2006 10:09 AM
Intermittent starting Problem Hopeless W126 S,SE,SEC,SEL,SD,SDL Class 6 02-25-2006 12:51 PM
1997 E320 Intermittent Starting Problem Explorer W210 E-Class 0 11-11-2005 05:48 AM
89 300E intermittent starting problem...HELP! crorrer W124 E,CE,D,TD Class 16 09-23-2005 04:44 PM
