Old 04-03-2007, 08:39 AM   #1 (permalink)
Date registered: Apr 2007
Overfilled gas tank
After overfilling my gas tank on my '00 E320, my gas gauge & computer readout is no longer accurate AND I have the distinct smell of gas in my garage after two weeks. No sign of leaking anywhere? Any suggestions?
maxfrankel is offline   Reply With Quote
Old 04-03-2007, 08:50 AM   #2 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI
There's a canister to absorb fuel vapors.
Overfilling tank could have filled this with liquid gasoline.
Nevertheless the hoses from this canister should be vapor tight.
Kent Christensen
Albuquerque
Old 04-03-2007, 07:03 PM   #3 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
It's probably worth a call to the service advisor at your stealership to ask for their input. My guess is you'll have to actually replace the canister, typically once they are hit with liquid they're usually ruined, but the SA should confirm/deny that based on a simple phone call.
Canisters are a pretty easy changeout (but not so easily paid for, particularly since it's a dealer item), so it's a DIY job if you're a DIY guy.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 04-04-2007, 01:54 PM   #4 (permalink)
Diego97's Avatar
Date registered: Feb 2007
Vehicle: 1997 E420 Sport-2004 Land Rover Discovery-2004 Mercedes Sprinter 3500-2001 Roadstar-1969 Chevy C10
so i understand this... you should never top off your tank with a few more clicks?
Diego97 is offline   Reply With Quote
Old 04-04-2007, 02:39 PM   #5 (permalink)
gregs210's Avatar
In a word, no.
Pretty much everything US certified since around 1980 has a charcoal canister and a sealed system. How the vapor lines are run, etc. affects how easily liquid fuel can get into the canister, but if you overfill enough you'll ultimately splash the canister with liquid fuel, and that destroys it. How much you can safely put in after the nozzle clicks off is an open question, at current gas prices you'd probably be safe with 50 cents, but why take the chance?
If you live in a state that requires vapor recovery fuel nozzles, they actually do a much better job of filling your tank to a safe limit before "clicking off" than do the non-VR type.
Greg
Old 04-04-2007, 03:44 PM   #6 (permalink)
Date registered: Dec 2006
Vehicle: 1997 E320, 1997 S320
spilling gas into the charcoal canister filter + having error codes, my guess would be a $500+ bill from the dealer.
tirona is offline   Reply With Quote
Old 04-04-2007, 07:52 PM   #7 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
I've been doing that my whole life. Usually we put close to a gallon after first click out. Never had a problem.
Kajtek1 is online now   Reply With Quote
Old 04-05-2007, 01:17 PM   #8 (permalink)
gregs210's Avatar
I know exactly what you mean, Kaj, I've done it on most cars I've owned, too; maybe I've just been lucky never to trash a canister. But I'd hate to suggest to someone that they go ahead and do it and then they end up flooding the canister, particularly on a pricey Benz product. Generally speaking I tend to be rather conservative with the suggestions I toss out on the forums, following that old rule of better safe than sorry. Or whatever it is.
Greg
Old 04-05-2007, 02:45 PM   #9 (permalink)
Date registered: Dec 2004
Greg,
What are the symptoms/effects of a trashed canister?
A few months ago, I filled my car up at a defective pump. The pump didn't shut off when the gas tank was full.
The tank expanded from the pressure and when I pulled the nozzle out, the recoil shot the gas back out of the car several feet for about 10-20 seconds. I know I got fuel in the vapor return line, since the engine stumbled a great deal afterwards as the ECU tried to cope with the raw fuel.
lexrex is offline   Reply With Quote
Old 04-05-2007, 05:20 PM   #10 (permalink)
Musikmann's Avatar
There is a warning label visable when I open the door to access the fuel filler cap on mine that clearly states: Do not top off. Thanks to the contributors here for explaining the reason.
Gas light flashing with gas tank full qha000 W140 S-Class 1 03-29-2007 09:52 PM
smell gas in and out ... gas tank cap? allerton W126 S,SE,SEC,SEL,SD,SDL Class 12 07-10-2006 05:55 AM
Full tank of gas, but slowly (over approx 30 min) will drop to empty, but tank full HACK THT W163 M-Class 6 06-22-2006 09:56 AM
Was something loose? I filled my gas tank, and my fuel meter never reset to the full tank reading.. AC_ML W163 M-Class 5 08-20-2004 08:12 AM
gas tank neanderthal W124 E,CE,D,TD Class 1 01-21-2004 11:39 PM
