Old 03-31-2007, 03:22 PM   #1 (permalink)
ProV1x's Avatar
Date registered: Jul 2006
Vehicle: E55 ///AMG
rear headrests not working properly..?
2 of the 3 headrests are messed up, they wont stay upright. if i force them to stay up, the release button does not lower them. is this a common problem..?? any ideas if this is an easy/hard repair.. thx
Gone but not forgotten:
2003 Honda S2000
1999 BMW 540i sport
1995 BMW M3
ProV1x is offline   Reply With Quote
Old 03-31-2007, 04:01 PM   #2 (permalink)
flw210's Avatar
Date registered: Feb 2007
Vehicle: 1998 Mercedes E320
Send a message via Yahoo to flw210
Today I was looking for the antenna amp location... I took out the molded carpets and the one immediately behind the rear seat and I saw the control unit/motor for the instant-down feature of the headrests. It's a circular device that had an air tube connected to it (it looks like it could do backup duty as a fish tank air pump). I could also see the bottom of the chrome hoops that are part of the headrests.
It's possible one of three things have gone wrong - 1) maybe something got caught in the chrome hoops or where they slide through as they are falling, for example wiring getting caught on the hoops, or maybe insulation as the car ages has come loose and gotten in the way or 2) maybe the air hose coming from the control unit has come loose giving only partial releasing power or
3) maybe the control unit for your instant-down has failed with age and somehow jammed some of your headrests in a way so they won't retract, or doesn't let them manually be in the upright position.
It's free to check possibility #1 & #2, but it might cost a little bit to replace possibility #3. It's also possible that your control unit is OK but the hose has cracks in it from age. If anyone has anything to add, that would be cool too.
Have a good weekend, hope this helps.
Tom
Take good care of your car and it will take good care of you.
flw210 is offline   Reply With Quote
Old 04-01-2007, 07:49 AM   #3 (permalink)
Date registered: Jan 2007
Vehicle: 2005 S500 4matic Sport Designo
when I bought my car, one headrest didn't want to stay up. The dealer replaced the little plastic clip that holds it up, and its been fine since. They still bounce a bit when they are down, but aside from that it all works fine.
OliverK is online now   Reply With Quote
Transmission not working properly VR6MAN W126 S,SE,SEC,SEL,SD,SDL Class 8 10-01-2006 09:55 PM
Instruments not working properly retiredinnc R/C107 SL/SLC Class 13 09-13-2006 09:07 PM
heater still not working properly boomie W163 M-Class 5 01-20-2006 02:04 PM
rear light not working properly jchilds23 W163 M-Class 7 05-03-2005 09:15 PM
Is my air working properly? Reggiefd General Mercedes-Benz 2 10-11-2004 08:42 PM
