Old 03-29-2007, 10:35 PM   #1 (permalink)
hilarushi's Avatar
Date registered: Jan 2007
Vehicle: 1998 E320
Exclamation Front Fog Light, Lits Problem ----Wired
I search around on the forum and could not find any answer to my problem.
On my 97 e420 only one of my front fog lights works. I have checked the buld ( switched) and also tested them and they both are ok.
what is wired is that the driver side works all the time but the passenger side does not work expect when it's humid, or when its raining. At least when it's humid it works 50% of the time. When dry/ sunny weather--- never works.
I know this is wired but that's what I have observed. and I think its very strange.
I have checked the wires by the bulb and there is no voltage there. while there is voltage on the drivers side.
The fuse is ok aslo.
On forums I read somewere that there is a relay by the battery!?!?! That might need to be dried.
Any idea, any help.
Will be greatly appreciated .
Current:
1998 Volvo S70
1998 SL500
Old Friends,
1998 E320
2004 Hyundai Tiburon
1997 Benz E420
1996 Lexus ES300
1988 Benz 300E
2000 Focus SE
2000 VW Jetta GL
hilarushi is offline   Reply With Quote
Old 03-29-2007, 11:25 PM   #2 (permalink)
raymond-'s Avatar
Date registered: Jan 2004
no power at the light....fuse okay
hmmm, headlight switch? jiggle, clean contacts, disassemble....
Step 1
search for headlight switch anomalies on the various forums
but i hope it's easier such as the relay or nearby connections. check schematic
for any inline type fuses just upstream of the light.
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
Old 03-29-2007, 11:41 PM   #3 (permalink)
hilarushi's Avatar
Vehicle: 1998 E320
Good link.
Step 1
Thanks for your quick reply. That was a good link but no help for this issue. I wonder if it is the switch that turns them on or a relay somewhere.
Old 03-30-2007, 07:35 AM   #4 (permalink)
tvo-2's Avatar
Date registered: Oct 2006
Vehicle: 2000 E 320 4Matic, '03 (50th anniv.) Corvette, '00 Land Rover Disco II, '85 Chrysler LeBaron Conv't
My 2000 e320 had the same problem....it was my passenger side fog light that intermittantly worked, along with both of my side marker lights...
i noticed that they NEVER worked after i went through a high pressure car wash....weird
but i had just gotten my entire passenger side fog light assembly replaced, so i brought the car to the dealership and they simply put in new bulbs...and i haven't had a single problem since (it's been a little over a month now...)
U see a hottie at a party & go up to her & say, I'm fantastic in bed- That's Marketing
U R at a party with friends & see a hottie, a friend goes up to her & says U R fantastic in bed- That's Advertising
U R at a party & see a hottie, U walk up to her & pour her a drink. U open the door for her, offer her a ride, & then say, By the way, I'm fantastic in bed- That's Public Relations
U R at a party and see a hottie, she walks up to U & says, I hear U R fantastic in bed- That's Brand Recognition!
tvo-2 is offline   Reply With Quote
Old 03-30-2007, 11:00 AM   #5 (permalink)
hilarushi's Avatar
Vehicle: 1998 E320
but there is no power to the bulb most of the time
There is no power to the bulb most of the time. And I have tested both bulbs.
Plus mine might work when it's humid.
Thanks for your reply ,
i will see what I can do.
Old 04-05-2007, 07:08 PM   #6 (permalink)
hilarushi's Avatar
Vehicle: 1998 E320
Problem Fixed
Thanks for your replies.
The problem was the contacts right by the housing. See pictures.
Clean them.
fog light problem negous R171 SLK Class 4 03-21-2007 02:46 PM
Need part, front plastic piece between front fog light tempoct R170 SLK Class 7 01-06-2006 12:02 PM
replacing front fog light bulbs... ewalberg G-Class 4 02-09-2004 11:13 AM
Front fog light glass replacement pete R170 SLK Class 3 03-11-2003 06:36 AM
Enabling Front Fog Light ? cabrone W163 M-Class 1 08-13-2002 11:41 PM
