Old 03-27-2007, 02:55 PM   #1 (permalink)
Date registered: Jan 2007
Vehicle: 2005 S500 4matic Sport Designo
4-matic front suspension
Im still chasing a slightly rough ride up front.
The 4 matic front end does not have sway bar end links, so thats out. It does have bushings for the sway bar, but mine look fine.
The only two things I come up with are struts and control arm bushings.
Who has had the control arm bushings replaced? what were your symptoms? Did the bushing completely fix them?
For those who replaced the strut, which ones did you buy? what were your symptoms? Did the struts fix them?
thanks.
OliverK is online now   Reply With Quote
Old 03-29-2007, 03:28 PM   #2 (permalink)
MAE320's Avatar
Vehicle: 2001 E320 4Matic Metallic Black
Been there with the same symptom. I do not know the mileage of your car. Mine was at 77K when I noticed the bumby ride. Dealer inspected and found both: bad sway bar and control arm bushings. Eventually they got replaced. Ride is 100% different now.
2001 E320 4-Matic
MAE320 is offline   Reply With Quote
Old 03-30-2007, 06:38 AM   #3 (permalink)
yeah, I have a feeling my control arm bushings are done.
4 matic disconnect 91 300 te 4 matic harley883 W124 E,CE,D,TD Class 10 06-19-2008 05:59 PM
w220 s500 4-matic front wheel drive e-gold-casino W220 S-Class 5 12-15-2006 08:38 AM
4-Matic Front Shock olehholy W210 E-Class 1 11-02-2006 09:04 PM
How much suspension travel is there on a SLK32 with OEM suspension; front & rear? Beng R170 SLK Class 1 01-23-2002 10:33 PM
My 300 TE 4-matic...grinding noise from front & 4-matic light on in dash display? Guest (MBNZ) W124 E,CE,D,TD Class 0 12-06-2001 06:32 AM
