Old 02-26-2007, 04:14 PM   #1 (permalink)
HOWSER's Avatar
Date registered: Feb 2006
Need New Cat
As the title says, I'm in the need of a new cat converter. Most of the quotes I'm getting are $450 - $500 installed. That just seems nuts!
I've seen hi-po converters for less than that it seems.
Who here has replaced one and what did it cost. Did you go back to stock or go for the performance ones?
All comments are appreciated.
Car is a 98 E320.
Eric
1998 E320; 93 Vette, Black on Black, Open Lid, K & N, Hooker LT's w/o cats, Side Effects Exhaust, C5 Wheels, 3.75's, Compucar Wet Kit (100 Shot), MSD Digital 6. 324 rwhp NA, 434 rwhp NO2.
HOWSER is offline   Reply With Quote
Old 02-26-2007, 05:04 PM   #2 (permalink)
Musikmann's Avatar
I don't know if your 1998 will qualify, but M-B has replaced CCs on cars with a lot of miles/years on them for free. I'd check with a dealer before going any further.
Old 02-26-2007, 05:47 PM   #3 (permalink)
HOWSER's Avatar
I just cracked 100k (103,000 to be exact). I wouldn't/didn't think they replace after 80,000. Has anyone heard of them replacing after the 100k mark?
Thanks for the info Muskimann.
Eric
Old 02-26-2007, 05:59 PM   #4 (permalink)
Musikmann's Avatar
Originally Posted by HOWSER
I just cracked 100k (103,000 to be exact). I wouldn't/didn't think they replace after 80,000. Has anyone heard of them replacing after the 100k mark? Thanks for the info Muskimann. Eric
Your welcome Eric,
80,000 miles might very well be the cut-off point, I just can't remember the precise details. Only that they were replaced fairly long after the original warranty was out.
Good Luck!
Old 02-26-2007, 06:08 PM   #5 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Don't forget that all important SEARCH function.
There's a post in here about aftermarket cats, I think they were magnaflow, both installed for under $300 if I remember right.
Meister Eckhart
Old 02-27-2007, 05:09 AM   #6 (permalink)
HOWSER's Avatar
Yes, I saw that. I was just hoping for additional input. Thanks though!
ML270 cat same as ML320 cat ? benzdriver737 W163 M-Class 1 06-10-2007 09:16 AM
I got my cat ID tiggerfink Off-Topic 12 11-10-2005 12:34 AM
Need help with cat..... euroamg W124 E,CE,D,TD Class 5 10-07-2005 03:29 AM
560 cat/non cat version Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 3 05-22-2002 10:48 AM
RB-Tech cat back, Does anyone make high flow cats to go with the cat back? Shawn KErr W208 CLK Class 5 03-11-2002 09:17 PM
