Old 02-26-2007, 04:01 PM   #1 (permalink)
barryd's Avatar
Date registered: Feb 2007
Changing the LoBeam HeadLamp Bulb
97 E320. Passenger side Lo Beam is defective. Can I just replace just the bulb or do I have to remove the entire headlamp Assy and then replace the bulb?
I tried to remove the assy by taking out the 2 #8 style screws. I carefully backed out the dohickey(?) that sits below the assembly (after also removing another #8) what is that thing by the way? After taht I carefully released the gasket material from the standoffs & restraints but the Headalamp Assy itself still seemed stuck. So rather than force it I put it all back together and have decided to write y'all instead.
There seems to be 4 choices for bulbs. Std, 55W, Blue and Super55. I live in Texas. Does it matter, the bulb that is, not living in Texas? Are the Blue ones legal? Do they help? Do I buy from MBZ in Austin or somewhere out on the Web?
Any help would help.
Thanks
barry
barryd is offline   Reply With Quote
Old 02-26-2007, 04:45 PM   #2 (permalink)
Musikmann's Avatar
Sorry, I can't help with most of this, but I can tell you that you will pay a lot more for a light bulb at any M-B dealer.
I have seen this place highly recommended:
Auto Parts at AutohausAZ - OEM Auto Parts - Discount Replacement Parts, Resources and Car Care Tips
Good Luck!
Old 02-26-2007, 05:59 PM   #3 (permalink)
raymond-'s Avatar
Date registered: Jan 2004
YouTube - MB W210 headlight remove
if you have skinny hands and triple jointed, you may be able to effect a bulb
change w/o removing the headlight housing from vehicle. but pulling the
assembly is so simple that I actually prefer to do it that way.
rarely will blue be legal....though variation of light blue can be shrugged of
depending on your LEO. hopefully you'll get a response from fellow Texan.
there are also different types of H7 from standard, to bright, to long lasting,
to fake bright, etc.
no need to buy exotics with H7. just go to your local auto parts store and
try out the Silvania Silverstars. more often than not, folks are happy with
this line. you may want to browse this and other MB forums to view and
consider their comments.
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
Old 02-26-2007, 06:07 PM   #4 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Just to clarify...if you own the post 2K facelift, changing the bulb is much easier.
Which is a good thing, because in order to remove the headlight assembly, you have to remove the bumper. (Sigh...)
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 02-26-2007, 06:52 PM   #5 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
It's not overly difficult to replace the bulbs without removing the headlight. However, it really is a five-minute job to remove the unit, and you should expect to lose some skin if you try to do the job from behind.
It's a good thing you stopped when you did, since there are three screws on each side. If you do remove it, be sure to not move the adjusters. The two small metal adjusters probably won't try to move, but be careful with the big white plastic one, at the lower inside edge of each headlight. It will move quite easily once you loosen the attaching nut. Getting it right again if you move it isn't a huge deal, but one best avoided.
Old 02-27-2007, 01:37 AM   #6 (permalink)
Date registered: Nov 2006
Vehicle: Oo == oO 98 E320
Is it my imagination or do about 1/3 of the posters on here not even bother to look in their owner's manual when the answers to their questions are there in black & white, well written with illustrations?
'87 300E: sold after 11years @ 230k & still on the road somewhere in rural Tennessee.
'94 C220 with 93k totalled 10/06 by hit & run broadsiding monster truck: not a scratch or bruise for me
johnamoss is offline   Reply With Quote
Old 02-27-2007, 09:00 AM   #7 (permalink)
The early 210 owner's manual says to change them from the back, which is other than what greg is suggesting. It is a somewhat painful operation, in fact.
So yes, the information is there. But no, it's not complete.
Old 02-27-2007, 11:37 AM   #8 (permalink)
I replaced both of mine from the back & did not find it painful...small hands?
Old 02-27-2007, 11:53 AM   #9 (permalink)
It wouldn't take a much smaller hand than mine to make it a much easier job. There's just barely enough room for mine.
Old 02-27-2007, 04:22 PM   #10 (permalink)
gregs210's Avatar
Just for the sake of clarification, I don't have the pre-facelift, and I was just quoting Raymond's suggestion to remove the entire assembly. My 2001, there is plenty of access to change the bulbs, low, high, city light, turn signal, etc. without small hands or removal of anything other than the access covers.
Take care and enjoy the "enlightened" ride,
Greg
How do I replace headlamp bulb. Darkmann W210 E-Class 2 10-31-2006 10:46 PM
Headlamp Bulb Replacement SLicK350 R171 SLK Class 19 09-28-2005 09:49 AM
Changing Headlamp, 98 E320 rac43 W210 E-Class 1 03-12-2004 10:01 AM
Headlamp bulb upgrades or questions? Check this out first... NWA-CRJ W201 190E, D-Class 1 01-15-2004 10:55 AM
Need help with replacing headlamp bulb on a 1997 C230. MikeT W202 C-Class 6 08-07-2003 09:26 AM
