Old 02-25-2007, 02:55 PM   #1 (permalink)
Date registered: Dec 2006
Vehicle: E300TD W210 1996
Diesel fuel leak
I have an issue with my wifes OM606 engined estate which has been well covered before - the air in fuel/not starting when parked up hill problem. I was about to attend to all the o rings/pipes etc etc but when I looked carefully I found it was leaking fuel (when running) from the top of the injector pump around outlets 1 and 2. Is this a common problem and is there an easy fix? Any help appreciated before I dive in! Thanks, Jon.
rsjon is offline   Reply With Quote
Old 02-25-2007, 03:40 PM   #2 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
leaks from injector pumps are common. what you are seeing is fuel leaking from the delivery valves which are on top of the pump. if I remember correctly, to fix the leak you remove the valves and replace the copper washers. either that or replace the valves assuming they come with new washers.
Streetglower is offline   Reply With Quote
Old 02-25-2007, 04:26 PM   #3 (permalink)
Vehicle: W210 E300TD
There is a specific torquing procedure for those delivery valves. I can't quite remember what it is but you'd do well to bear it in mind. IIRC its 35nM, loosen off, then retighten - something like that.
Parrot of Doom is offline   Reply With Quote
Old 02-25-2007, 11:06 PM   #4 (permalink)
biodieseler's Avatar
Date registered: Oct 2006
I had the same problem. Replaced the o-rings and copper seat using a 32 point socket that I had to order from a specialty tool place. It was an easy fix. BUT now for me I just noticed another fuel smell this evening. Pulled the valve cover off and noticed at least three of the injector holes filled to the brim with diesel. I already replaced the fuel return lines so i dont know. Anybody have a similar problem and have the remedy. Is there a seal around the injectors or something.? Any help would be great.
97 E-300 Biodiesel
1997 E300
2001 VW TDI
1996 Dodge 1 Ton Cummins
2006 Dodge 1 Ton Cummins
biodieseler is offline   Reply With Quote
93 300D diesel fuel leak help axm1955 W124 E,CE,D,TD Class 1 01-30-2007 04:35 PM
Fuel leak at the fuel pump RAF W126 S,SE,SEC,SEL,SD,SDL Class 5 07-06-2006 10:19 PM
Diesel leak around fuel tank? Jonathan Joseph G-Class 7 04-03-2006 03:01 AM
Air leak in diesel fuel lines C250d or E250D JOHNWOLFM General Mercedes-Benz 0 12-12-2004 02:31 PM
Diesel Leak Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 0 08-07-2001 03:03 AM
