Old 02-25-2007, 10:47 AM   #1 (permalink)
Date registered: Feb 2007
Vehicle: 1999 E3OOTD Maroon/Tan
Check Engine/Glow Plug lights on
Please forgive my ignorance but I'm new to MB ownership.
1999 E300 Turbo Diesel. Been running perfectly. After starting it this morning, the Check Engine and Glow Plug lights came on. It's idling the same as usual. I shut it off and restarted several times with the same results. Any ideas?
My nearest repair shop is 60 miles away. Is it safe to drive it there?
Thanks.
EufaulaE300TD is offline   Reply With Quote
Old 02-25-2007, 11:00 AM   #2 (permalink)
Date registered: Nov 2002
Vehicle: 560 SEC Supercharged(sold), E55 AMG, Renntech CL600 Bi-turbo, Porsche 928
Wrong forum. Try the 210 forum. This one is for 210 AMG's.
Supercharged SEC is offline   Reply With Quote
Old 02-26-2007, 06:10 AM   #3 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
You've got a bad glow plug. To be sure take it to an Autozone or such and have the code read or you can take an ohm meter to the relay box connector and measure each plug's resistance. Good plugs Will measure about 0.6 ohms cold. Then read about stuck and broken glow plugs on this engine to be an informed consumer.
Len
sokoloff is offline   Reply With Quote
Glow plug(s) or glow plug relay...? kavakava W123 E,CE,D,CD,TD,TE Class 7 01-28-2008 08:10 PM
Glow plug problems, no power to the glow plug relay kbbenz78 W123 E,CE,D,CD,TD,TE Class 8 11-15-2006 09:45 PM
Late Glow glow plug relay smallfence W123 E,CE,D,CD,TD,TE Class 14 07-20-2006 01:40 AM
glow plug light only comes on when 5 pin plug is disconnected from relay JLincoln W123 E,CE,D,CD,TD,TE Class 5 11-20-2005 05:58 PM
99 E300 Diesel - Glow plug and check engine light at the same time! dsellsbear W210 E-Class 4 03-05-2004 10:08 AM
