Old 02-24-2007, 04:42 PM   #1 (permalink)
Mr A's Avatar
Date registered: Oct 2006
Vehicle: Black on Black 1999 E320
Send a message via Skype™ to Mr A
Coolant Sensor Location?
I wanted to know where this sensor is so I can change it, any help is appreciated.
Thank you.
Mr A is offline   Reply With Quote
Old 02-24-2007, 07:12 PM   #2 (permalink)
Mark Cummins's Avatar
Vehicle: W211/W210wagon/W209
Its located in the coolant overflow tank
Mark Cummins is online now   Reply With Quote
Old 03-04-2007, 12:12 PM   #3 (permalink)
Mr A's Avatar
Can it be changed by simply opening the hood or do I have to jack up the car and change it.
Old 03-05-2007, 09:48 AM   #4 (permalink)
Date registered: Jan 2007
Vehicle: CLK 55 AMG W208
Are you sure you need to change it ? If the warning light is stuck on the problem may be the washer fluid level switch open circuit. Do a search on the forum.
Best wishes.
dickchailey is offline   Reply With Quote
Old 03-05-2007, 11:50 AM   #5 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI
If you ask this after being told it's on the coolant overflow tank, you haven't a clue and would be best advised to take your car to a professional.
Kent Christensen
Albuquerque
Location of engine block coolant plug on 300SE mansito W126 S,SE,SEC,SEL,SD,SDL Class 4 07-19-2006 06:32 PM
95 E200. Oil sender sensor location, brake pad sensor location, engine code? cubicincubi W124 E,CE,D,TD Class 2 01-04-2006 09:07 AM
02 sensor bank 1 sensor 2 location sling_lphie W163 M-Class 0 07-27-2004 08:08 PM
Engine Block Coolant Drain Location? Vincent W126 S,SE,SEC,SEL,SD,SDL Class 2 01-09-2004 09:12 PM
Coolant Drain Plug Location twalter W163 M-Class 8 12-30-2003 12:42 PM
