Old 02-24-2007, 07:58 AM   #1 (permalink)
ProV1x's Avatar
Date registered: Jul 2006
Vehicle: E55 ///AMG
intermittent starting problem, 97 E420. battery fine
this seems to occur after i've driven for a while, let the car sit for a few hours and then try to fire her up again. i would crank for 4-5 seconds but the car won't start. does not happen on a completely cold (overnight) engine.
anyone know what might be causing this? thanks
Gone but not forgotten:
2003 Honda S2000
1999 BMW 540i sport
1995 BMW M3
ProV1x is offline   Reply With Quote
Old 02-03-2008, 11:21 AM   #2 (permalink)
Date registered: Oct 2002
I have the exact sam problem. Did you discover a solution?
ssickler is offline   Reply With Quote
Old 02-16-2008, 08:46 AM   #3 (permalink)
Date registered: Sep 2004
Vehicle: 99' e320w 4matic
You can find a ton of threads for troubleshooting this problem. I went thru all of them replacing MAF, cranshaft sensor etc. etc. dealer finally had car not start and tech. found faulty fuel pump relay that was intermittent.... $40. part fixed it after months of troubleshooting and replacing DIY components. "99" e320.
carver is offline   Reply With Quote
Old 02-16-2008, 11:09 AM   #4 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
It is easy to test the fuel pump by putting tester light to the fuse and see how the power go.
The symptoms of engine hard to start when hot and no problem with cold are common for leaky injectors. If the injector leaks fuel after stopping the engine, it floods the engine making it very hard to start soon after. Cold engine needs extra fuel to start, so this is fine.
Next time when that happens, push the gas pedal to the floor while cranking. That always worked on older cars with mechanical throttle. Can't guarantee what computer will do on those babies.
Kajtek1 is online now   Reply With Quote
Intermittent starting problem -E240 nikko W210 E-Class 3 06-15-2007 06:14 PM
Intermittent starting Problem Hopeless W126 S,SE,SEC,SEL,SD,SDL Class 6 02-25-2006 12:51 PM
1997 E320 Intermittent Starting Problem Explorer W210 E-Class 0 11-11-2005 05:48 AM
89 300E intermittent starting problem...HELP! crorrer W124 E,CE,D,TD Class 16 09-23-2005 04:44 PM
Starting Problem 1993 300sd - intermittent mbdiesel W140 S-Class 6 06-08-2005 09:23 PM
