Old 02-22-2007, 08:22 PM   #1 (permalink)
Date registered: Feb 2007
No start...
Hi guys, new here. I have a 1997 E320. The problem is the vehicle cranks but does not start. Long story short the injectors are not getting the ground signal. Anyone has any advice?
Things I've cked: fuel pressure, fuel flow, has spark, replaced camshaft position sensor, has voltage to injectors, ohmed crank sensor at 1.10kohms, new battery. The car will run with starting fluid.
donaudi is offline   Reply With Quote
Old 02-22-2007, 10:08 PM   #2 (permalink)
Wireharness cked ok. Does anyone have wiring diag for the injectors or the ecu? What inputs does the ecu need to shoot injectors?
Old 02-23-2007, 07:00 AM   #3 (permalink)
Vehicle: Currently have a 98 E300TD 270000 miles, 98 E300TD 208000 miles, 98 E300TD Estate 130000 miles
Send a message via MSN to mr_benz
Have you checked the CKP sensor (crankshaft position sensor), i had a E300TD with the same fault, also you need diagnostic equipment to check the ECU.
mr_benz is offline   Reply With Quote
Old 02-23-2007, 02:00 PM   #4 (permalink)
camshaft sensor was replaced. and no check engine codes with diag using scan tool.
Old 02-26-2007, 11:09 AM   #5 (permalink)
possible computer?
Old 02-26-2007, 11:20 AM   #6 (permalink)
ProV1x's Avatar
Date registered: Jul 2006
Vehicle: E55 ///AMG
looks like you've done a lot of work already. were they done diy or by your indy's recommendation?
i'd look at MAF and o2 sensors next.
Gone but not forgotten:
2003 Honda S2000
1999 BMW 540i sport
1995 BMW M3
ProV1x is offline   Reply With Quote
Old 09-09-2008, 07:50 PM   #7 (permalink)
Date registered: Sep 2008
Vehicle: 1997 E320
I have the same problem on a 1997 E320 it cranks and runs for 20 seconds the most then dies,usually it's more like 2 seconds running,i changed out the cps and it started and ran for almost a minute then just died again,i have fuel pressure and no codes,weird thing is if i step on the gas it instantly dies also i took off the MAF and it looks clean,left the MAF off and started the engine while blocking the intake hose and it ran for as long as i blocked the intake hose,anyone have any ideas?
NELSON76 is offline   Reply With Quote
Old 09-10-2008, 11:19 AM   #8 (permalink)
slybydesignw210's Avatar
Date registered: Jan 2007
Vehicle: Pearl White 1994 Q45T
Clean your MAF
3. Paul Hamm, Gymnast: I owe a lot to my parents, especially my mother and father.
"I would hate to see a VIP car with anything but a Japanese motor. It's like putting fried chicken in your sushi :d2td" Nico Member Comment
slybydesignw210 is offline   Reply With Quote
Old 09-10-2008, 02:26 PM   #9 (permalink)
Date registered: Aug 2008
Vehicle: on the search for another 97 202.028 many more sold
i belive the ground for the injectors are supplied by the M.E.
nicole21 is offline   Reply With Quote
Cold Start/Hot Start/Idle joesette W124 E,CE,D,TD Class 6 01-01-2007 09:18 PM
sl500 cold start fine-short trip park restart rough idle hard start?? dpol1835 R129 SL Class 7 01-02-2006 07:33 AM
Cold Start? hard to start after temp drops Prissy6990 W126 S,SE,SEC,SEL,SD,SDL Class 4 02-15-2005 07:51 PM
Hard start or second start when warm high hc level-- beware major expense Peter Seow W126 S,SE,SEC,SEL,SD,SDL Class 1 07-03-2004 07:23 PM
Should my 1989 190e start in 2nd gear unless floor it from start? Guest (MBNZ) W201 190E, D-Class 5 08-01-2002 01:27 PM
