Old 02-22-2007, 01:34 PM   #1 (permalink)
Date registered: Feb 2007
E430 check engine light
My CEL came on and the car runs great. I'm considering going to Autozone to rent a OBD ll. Does anyone know if a generic OBD works on Mercedes? Also, if it does work will there be some way to interperet the given codes. What do dealers/shops charge to run the codes. Anyone know?
Dennis H is offline   Reply With Quote
Old 02-22-2007, 01:39 PM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Try Auto Zone first. Don't clear any codes unless you have changed parts, as a repair shop may need the additional information that is stored (freeze-frame data, particularly).
If there are P0xxx codes, A-Z should be able to translate it for you if the tool itself does not. If there are P1xxx codes, it's M-B specific so post them here.
Old 02-22-2007, 02:08 PM   #3 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Agree with the other post, just FYI to our thread starter that OBD-II is "generic", that's the whole point of it.
Take care and enjoy the ride,
Greg
Meister Eckhart
would blown dashboard light make check engine light go on? ae98 R170 SLK Class 3 10-07-2006 01:36 AM
Check engine light – Code 4 (on plug itself – red light on diag. mod.) & Pin 14 CC/ETA gives Cod rwogs W124 E,CE,D,TD Class 0 12-19-2005 08:39 PM
check engine light & flashing fuel guage light pd99sl500 R129 SL Class 7 02-27-2005 05:31 PM
wierd engine behavior w/ check engine light, dealer unable to solve spovilaitis R170 SLK Class 6 12-12-2003 09:05 PM
Help Please!!! Check Engine Light...Empty Fuel Light Flashing mJstk01 R170 SLK Class 6 05-18-2003 11:53 AM
