Old 02-20-2007, 03:13 PM   #1 (permalink)
Date registered: Aug 2006
Vehicle: 1997 E320 Avantgarde
5th gear
At approximately what speed should the transmission kick to 5th gear? Will it do it automatically or am I required to flick the lever? I always assumed that 5th gear would just happen automatically like a lot of my other cars (Japanese)?
Will someone out there run me through.
1997 E320
(I6)
Cheers
laksa is offline   Reply With Quote
Old 02-20-2007, 05:24 PM   #2 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI
It happens automatically.
When depends on throttle position.
Kent Christensen
Albuquerque
Old 02-20-2007, 05:28 PM   #3 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hey, laksa.
It should upshift all on it's own. Mine kicks in someplace near 40 if I'm just cruising around.
You ever changed the fluid and filter in it?
Double-check your manual re: operation of the W/S switch, that may make a difference as well.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 02-20-2007, 06:35 PM   #4 (permalink)
Hey thanks guys. What is the point of the lever selection if it's going to do it automatically?
Cherrs
Old 02-21-2007, 02:20 AM   #5 (permalink)
Date registered: Nov 2006
Vehicle: Oo == oO 98 E320
So you can select any other gear 1st thru 5th. For example, you can downshift a gear or two when going down a steep hill. You might want to read your manual. It's all there.
'87 300E: sold after 11years @ 230k & still on the road somewhere in rural Tennessee.
'94 C220 with 93k totalled 10/06 by hit & run broadsiding monster truck: not a scratch or bruise for me
johnamoss is offline   Reply With Quote
5th Gear won't engage faisal300ce W124 E,CE,D,TD Class 30 05-16-2007 02:10 PM
5th gear missing on s320 help!!!! roysofia W140 S-Class 21 11-20-2006 06:20 PM
5th Gear SL vs SLK 55 video Easty R171 SLK Class 16 02-14-2006 06:20 PM
Lost 5th Gear in autobox...what's going on? mjtray W210 E-Class 1 12-20-2005 10:00 PM
5th gear tb manchester R171 SLK Class 10 03-31-2005 05:09 AM
