I am building a custom mount for my GPS Navigation unit to sit right on the ledge above the center vent mounts.
My intention is to secure the mount behind the strip of wood trim and run a power connector behind the trim.
Does anyone have any instructions on properly removing and reattaching the strip of wood above the center vents that stretches across the passenger side?
see if this helps. there's a series of videos devoted just on dash dis/assembly so
there is lot more....about 70mb worth. you'd prob need to buy the DVD from MBUSA.
i did see Mr Pie hosting same disk but his site appears to be down at the moment.
Thanks!
-Jeff
Just open the side panel & top right speaker (used for phone), then pull it out from right to left.
These are instructions taken from WIS. Hope it helps.
Cheers.
“Design embodies the values of a company. Even if there were no star, the car must always be recognizable as a Mercedes-Benz.” Peter Pfeiffer, Daimler AG
