Old 02-15-2007, 10:50 AM   #1 (permalink)
Date registered: Feb 2007
Vehicle: 99 E430 Sport
Fusion iridium and platinum center electrode sparkplugs for E430 99
Should I get this for my car and is it safe to use this?
these are the top of the line from Bosch and was told it would ok to use it in my car
I have a E430 99 Sports
http://www.boschautoparts.com/Produc...s/IrFusion.htm
Please let me know what you guys think.
Thanks
Michael
99 E430 Sport
Last edited by Totalfixation : 02-20-2007 at 10:36 PM. Reason: Fix the product name.
Totalfixation is offline   Reply With Quote
Old 02-15-2007, 10:56 AM   #2 (permalink)
also i used there Vechicle part finder and came up with this
http://www.boschautoparts.com/RB.NA....=MERCEDES-BENZ
the Iridium has no gap while the FR8DPP332 has a gap of .40.
would there be any difference with that?
Old 02-15-2007, 01:44 PM   #3 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hey, TF, welcome to the forum.
I'll repeat what I generally say about spark plugs. If your car runs fine with the ones MBZ originally put in and it's otherwise stock (i.e., no aftermarket blower, etc.), then pull one out (an easy one) and examine it, if the color looks good then just buy a set of what's in there. It's not as though stock plugs are junk, and the difference in price to the high-end premium plugs isn't going to net you anything noticeable beyond (1) a larger dent in your wallet and (2) a longer lasting plug. Driveability, startup and fuel economy will remain the same whether you install the high-dollar plugs or a new set of the OEM ones.
That said, any premium plug should work just fine, including Bosch's latest and greatest.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 02-15-2007, 03:08 PM   #4 (permalink)
well the thing is i have a 25% percent coupon off at kragens and they sell only the Bosch Platinum +2, +4 and the fusions which are iridium and no OEM. So i thought it be good to get the Fusion for the same price as if i was to get OEMs at a local auto parts place.
It seems that my car is a little shaky on first startup of the day and while idle it shakes a little. could it be the spark plugs?
I was thinking of getting the Fusion for piece of mind and hopefully get some better gas mileage out of it. My car is at 80K so far.
Old 02-15-2007, 04:41 PM   #5 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
You can't adjust the gap on those Iridium plugs, which is why it's not listed. Platinum plugs do have a gap, but you're not supposed to adjust them; they're supposed to be pregapped from the factory for the particular application.
But I completely agree with Greg. If your car isn't missing, you won't get more power from expensive plugs. It's possible that they will last longer, but not a given.
I've had a few engines that hated Bosch Platinum plugs (this was before the Iridium plugs were out) and missed badly after just a few weeks. $1 Champion plugs worked great for a year in them.
Old 02-15-2007, 05:23 PM   #6 (permalink)
ya i heard people telling me platinums were giving alot of problems but if i could Iridiums for the same price as the OEM would it be ok? on bosch's website they list them under my vechicle but then again they list the platinums, +2 and +4.
Old 02-15-2007, 05:45 PM   #7 (permalink)
gregs210's Avatar
If you're not paying a price premium I can't imagine them giving you any problems. Since your rough idle is just at cold startup it may be plug related, but in any event you'll know after you change them.
Greg
Old 02-16-2007, 12:28 AM   #8 (permalink)
well its also on reverse and sitting idle sometimes at a light, but it comes and goes, but when reversing it vibrates all the time. Im guessing it could be the engine mount.
Old 02-20-2007, 10:38 PM   #9 (permalink)
So has anyone used the Fusion sparkplugs yet, Please please someone tell me, im so wanting to buy it. i can really get a good deal on it, but alot are saying stick with OEM.
Old 02-21-2007, 05:24 AM   #10 (permalink)
Date registered: Jan 2007
Vehicle: 2000 E430 4Matic
Stick with OEM
Mercedes is a well engineered world class automobile. They would not have put in low or medium grade parts that will affect the performance. I have used platinum +4, platinum, Denso Irridium, and my consensus, stick with OEM.
2000 E430 4Matic
Owned:
2001 Audi A8L
2001 GMC Denali
1997 Audi A8
1995 BMW 325IC
1991 300E 4Matic
1997 & 1994 Landcruiser
1995 Range Rover LWB
2000 GMC Denali
1997 Discovery
1992 & 1987 Saab 900T Conv
1992 SVX
1991 BMW 750IL
1991 Mustang 5.0 LX Conv.
leeah is offline   Reply With Quote
E430 center console tray problem blkE430sport W210 E-Class 0 02-06-2007 08:06 AM
Bosch Spark plugs Platinum 4 VS Platinum 2 98_ml320 W163 M-Class 9 02-05-2006 02:49 PM
Spark plugs, who's work best, and how about Platinum or Iridium plugs? Bruce R. W201 190E, D-Class 2 07-11-2003 05:25 AM
multi-electrode spark plugs heckflosse W124 E,CE,D,TD Class 2 02-08-2003 03:18 PM
Why did Mercedes used BOSCH super plug instead of BOSCH Platinum +4? I install Bosch Platinum +4 ... Linh R170 SLK Class 19 10-06-2001 03:49 PM
