2000 E320 - flashing low fuel light - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 02-07-2007, 10:56 PM Thread Starter
Date registered: Aug 2005
Send a message via MSN to salaburg
Cool 2000 E320 - flashing low fuel light
I have this random problem with the low fuel light. irrespective of the amount of fuel in the tank, sometimes the low fuel light flashes at a speed similar to an instrument cluster indicator flasher when there is a bulb blown (faster than normal flash). This problem is intermittent. It may not do it for a few days then it will flash all day, regardless of whether I turn the ignition off to try and reset. Anyone have any ideas before I take it to a dealer?
salaburg is offline
post #2 of 10 (permalink) Old 02-08-2007, 03:29 AM
jka
Date registered: Aug 2006
Check your gas cap.
jka is offline
post #3 of 10 (permalink) Old 02-08-2007, 07:20 AM
my merc 4's Avatar
Date registered: Oct 2006
Vehicle: 2007 VW Rabbit
Send a message via AIM to my merc 4
Originally Posted by jka
Check your gas cap.
hmm i thought that that problem usually flashes the check engine light. but i still agree with you in checking the gas cap.
past ride:
1999 E430-sold
my merc 4 is offline
post #4 of 10 (permalink) Old 02-08-2007, 09:57 AM
Musikmann's Avatar
Quoted: 6 Post(s)
That's the way I understand it too.
Musikmann is offline
post #5 of 10 (permalink) Old 02-08-2007, 11:04 AM
jka
Check Engine comes on if you let it go too long.
jka is offline
post #6 of 10 (permalink) Old 02-08-2007, 11:21 AM
KADE's Avatar
Date registered: Jan 2006
Vehicle: E-350/2010 4-MATIC (E-320/2000 R.I.P.)
Flashing fual light indicates that the fual cap is not on properly or tight enough, unless their is a problem with the wire thats connected to the fual cap, that might make the low fual warning appear also.
KADE is offline
post #7 of 10 (permalink) Old 02-08-2007, 08:51 PM Thread Starter
thanks guys.... I havent tried the experiment but I dont think I need to.... the amount of times that I have found the gas cap loose, just resting, or even off completely after my wife has been to the gas station is anecdotal enough! I have pledged that "I" will be the re-fueler from now on, so lets see... the light should no longer come on.
cheers
salaburg is offline
post #8 of 10 (permalink) Old 02-09-2007, 01:32 PM
Date registered: Sep 2006
Vehicle: 1996 E320
yeah its most likely the cap...usually check engine light comes on with the flashing low gas but thats not the case here...also if you open your trunk and u remove the panel straight ahead where the back seats are there should be some wires that u should try moving cause they connected with gas...but just see what happens with the gas cap
Creative85 is offline
post #9 of 10 (permalink) Old 03-16-2007, 02:54 PM
Date registered: Feb 2007
Vehicle: 1999 E430 Sport
Flashing low fuel light
I had the check engine light and flashing low fuel light come on. Tried a new gas cap and that didn't solve the problem. The mechanic I go to hooked up a smoke machine to the fuel system. It basically injects smoke into the fuel system so you can visually determine if there is an air leak. It turned out to be the evap solenoid. After that was replaced, no more check engine light or flashing low fuel light.
blkE430sport is offline
post #10 of 10 (permalink) Old 08-03-2009, 02:14 AM
Date registered: Dec 2006
Vehicle: 2000 E430 4Matic
Where is the evaporator solenoid located ?
Whether you think you can or cannot, Either way you're right!. by Henry Ford.
benz3000 is offline
    Low Range Light Flashing Joe W163 M-Class 21 01-09-2016 06:19 AM
    (problem) - low range light kept flashing soulsociety714 W163 M-Class 60 06-05-2012 12:44 AM
    Flashing fuel low light, tight gas cap..what up with this? doctorkaligari R170 SLK-Class 10 06-07-2010 06:18 PM
    Q: Possible causes for Flashing low-fuel light (other than gas cap)? benkokes R170 SLK-Class 4 08-30-2004 09:15 AM
    Flashing Low Range Light jmd6936 W163 M-Class 3 09-23-2003 07:00 PM
