Old 01-24-2007, 08:09 AM   #11 (permalink)
G-AMG's Avatar
Date registered: Oct 2005
Vehicle: '04 G55 '80 280GE '99 S420 '98 E320
Actually these are the SECONDARY Cats. The Lamba probes are FORWARD of these Cats shown, and behind the FIRST STAGE Cats.
Removing the secondary Cats may screw things up due to TOO LITTLE backpressure on the exhaust system. That's my understanding. I am a novice in these matters, like most of us.
This is why they suggest you have a "Flow Test" done on the existing Cats you have, just to make sure the Replacement Cats are of the same "Flow Resistance."
My .02.
G-AMG is offline   Reply With Quote
Old 01-24-2007, 08:12 AM   #12 (permalink)
G-AMG's Avatar
For reference, the Right sided Lambda Probe (O2 sensor) is in the second photo, lying horizontal, and right at the level of the tire. About 3-4 inches long.
Old 01-24-2007, 09:29 AM   #13 (permalink)
ProV1x's Avatar
Date registered: Jul 2006
Vehicle: E55 ///AMG
as usual G-AMG excellent work & writeup!
that's so much cheaper than OEM.. do you know the part # for 1997 E420? my car's got 109k miles and i'm sure i'll need new cats sometime in the future..
Gone but not forgotten:
2003 Honda S2000
1999 BMW 540i sport
1995 BMW M3
ProV1x is offline   Reply With Quote
Old 01-24-2007, 02:03 PM   #14 (permalink)
G-AMG's Avatar
ProV1x,
The Magnaflow 53005 is a "Universal Fit" Cat, 2.25" You'll have to double check the size of your pipes, but fairly sure it's the same.
HOPEFULLY it'll be a long time before yours go.
Old 09-17-2007, 05:23 PM   #15 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hey, G-AMG, since these have to be welded in I added it to the FAQ/TIPS sticky. That way I don't have to go searching for it again.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 05-07-2008, 11:07 AM   #16 (permalink)
Date registered: Apr 2008
Vehicle: 2000, E-320
Nice detail
have to say a very nice piece and well done...thank you for that...I think I could do this at my work...as we have car lifts...so I could do it on a saturday with out much issue...
I have just purchased a 2001 E-320 and one of the catalytic converter...didn't know there was two for each side...but this is the back one...as my guy when he was changing the oil...showed me by banging on it..and you could hear it rattle...
What I have a question on is what is the difference in MB parts and OEM parts...as he told me he wouldn't use OEM parts...said it wouldn't work right with the engine...what is the expereince been??? I thought OEM were approved by MB...
Thank you...
daniald is offline   Reply With Quote
Old 05-07-2008, 04:48 PM   #17 (permalink)
gregs210's Avatar
Thank you...
Hi, daniald, and welcome to the forum. Please take a moment to complete your BW profile.
There are actually four cats on your car (and four 02 sensors as well). There is a thread somewhere discussing aftermarket cats wherein Matt posted an interesting PDF to the effect that aftermarket cats were not as good as original. That's a decision you'd have to make for yourself, but cost wise the difference is huge. That might be what your mechanic is referring to.
Also, I'm not aware of any aftermarket cats that are approved for use in CA, only 49-state versions. If you're in CA that might be an issue as well.
Greg
Old 05-07-2008, 05:27 PM   #18 (permalink)
ohlord's Avatar
oem
means original equipment manufacturer the units from racepages.com are good units.The units from autohausaz.com are oe or oem as well.I would be leery of a mechanic that did not know what oem means----it means it was made by the same company that supplied the same part to mercedes the day the car was assembled .Buy a mercedes mass air sensor from the dealer for $450 plus or buy the oem bosch unit for $170 from autohausaz.com you choose in your case I would choose another mechanic
ohlord
Old 05-07-2008, 09:58 PM   #19 (permalink)
Date registered: Aug 2005
Vehicle: 2001 E320
G-AMG,
I assume that you have to remove the pipe from the vehicle to weld the cat in. right?
Thanks.
cerritos is offline   Reply With Quote
Old 05-08-2008, 12:42 AM   #20 (permalink)
gregs210's Avatar
Hey, Cerritos.
Usually they just cut out the old one with a saws-all and weld the new one right in. That is faster and easier, thus saving you money, and it makes it easier to assure the proper alignment, which is also important.
Greg
f**k my cats mrmacp W210 E-Class 18 02-08-2007 07:26 PM
2 cats? MEOWWWWW ALephart R170 SLK Class 6 01-08-2007 09:31 PM
Cats out of warranty, Texas W210 E-Class 8 12-19-2006 04:18 PM
Could it be Cats? Texas W210 E-Class 1 11-28-2006 05:11 PM
320 how many cats a204600 R170 SLK Class 1 04-01-2005 09:59 AM
