Old 01-22-2007, 02:40 PM   #1 (permalink)
ProV1x's Avatar
Date registered: Jul 2006
Vehicle: E55 ///AMG
Can I run 205/55/16 tires on my OEM wheels
I'm buying some snow tires and I like Dunlop Wintersport M3. I'm thinking of getting 205/55/16 size vs. 215/55/16 b/c I heard narrower is better, and also the 205s are cheaper. There'll be 1.7% speedo error, which I think is within allowed spec (+/- 3%). any ideas?
Gone but not forgotten:
2003 Honda S2000
1999 BMW 540i sport
1995 BMW M3
ProV1x is offline   Reply With Quote
Old 01-22-2007, 02:53 PM   #2 (permalink)
Avantgarde 1998's Avatar
Date registered: Jan 2006
Vehicle: E200KOMPRESSOR
I think you can ProV1x..It is not a big change and since you are talking about winter tires..ofcourse narrower is the better.
MICHALIS :
Avantgarde 1998 is offline   Reply With Quote
Old 01-22-2007, 06:00 PM   #3 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hey, Pro.
It's not going to hurt anything on your car to do that, just log a few more miles than you actually travel and reflect a slightly-higher speed than you're actually going. I can't imagine a few more miles would do too much to the resale value, particularly since you're only running them in winter.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 01-23-2007, 09:41 AM   #4 (permalink)
Date registered: May 2004
Vehicle: 97 E320 130k miles
It doesn't make sense that the 2 tires that you're comparing will have a different reading on the speedometer... 215 vs 205 compares width only. The circumference of the tire doesn't change, they're both xxx 55r16.
By the way, narrow is better for a snow tire. Love my Blizzak's, but any snow tire will work for all but the worst winter storms. Go with it and drive safe.
smazur is offline   Reply With Quote
Old 01-23-2007, 09:52 AM   #5 (permalink)
jlomon's Avatar
Date registered: Dec 2006
Vehicle: 2000 E320 4Matic Wagon, 1994 C280
It makes complete sense, actually, when you consider what each number on the sidewall means. The "55" is a percentage, meaning that the sidewall height is 55% of the tread width. 55% of 205mm is 112.75mm and 55% of 215mm is 118.25mm. The narrower tire results in a smaller total diameter of wheel and tire combined. This results in more revolutions per mile, which puts the speedo out of whack.
Narrower is definitely better in a snow tire. I wouldn't worry too much about 1.7% error. Chances are your speedometer isn't that accurate anyways. Its a negligible amount.
jlomon is offline   Reply With Quote
16" W210, 211 Mono Block Wheels with Good Year EAGLE F1 205/45R16 TIRES Sky_Line For Sale, Trade & Wanted Items 0 06-11-2006 09:00 PM
Will 205/55/16 Tires fit on 16x8 wheels nicely?? Thanks... andyt The Discount Tire Direct Tire, Wheel, Brake & Suspension 3 10-24-2002 09:29 AM
Question: Will 205/55/15 tires fit on 16x8.5 wheels nicely? andyt R170 SLK Class 6 10-13-2002 04:27 PM
Dealer recommanded 205/55/16 snow tires for front AND rear, will the 205/55/16s fit the rear rims? doraemon R170 SLK Class 3 12-07-2001 01:43 AM
Should I use 7*16 or 7,5*16 wheels for 205/55/16 Tires? Anders Davidsson R170 SLK Class 2 10-09-2001 11:18 AM
