Old 01-22-2007, 01:37 PM   #1 (permalink)
Date registered: Jan 2007
Vehicle: 2000 E430 4Matic
Instrument Cluster Removal
Boy, this is tougher than I thought. Used the wire hanger and cannot get this thing out........
leeah is offline   Reply With Quote
Old 01-22-2007, 03:08 PM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
The clips hold it pretty well. Once you get it moved about 1/8" on each side (one side at a time) it comes out easily.
Old 01-22-2007, 09:13 PM   #3 (permalink)
Date registered: Aug 2006
Vehicle: 2001 E430 Sport (there is a God); 1986 560 sec; 1983 300 sd (sadly, dead)
It really is possible to remove the cluster with your bare hands. I've been successful at it a few times, and it just takes some patience and a good grip. Give it a try if you cannot manage with the hooks.
chino26 is offline   Reply With Quote
Old 01-22-2007, 09:52 PM   #4 (permalink)
G-AMG's Avatar
Date registered: Oct 2005
Vehicle: '04 G55 '80 280GE '99 S420 '98 E320
Save yourself ALOT of possible anguish (AND EXPENSE!!--The Instrument Cluster is VERY Expensive, and VERY Easy to BREAK/CRACK).
For the 20 or so bucks, get yourself some OEM hooks, and do it the correct way!
I am inclosing the WIS instructions. Be sure you angle the hooks laterally, as indicated.
Good Luck!
G-AMG is offline   Reply With Quote
Old 01-22-2007, 09:58 PM   #5 (permalink)
G-AMG's Avatar
WIS Instructions
Sorry, Let me try Uploading one more time.
Old 01-28-2007, 06:08 PM   #6 (permalink)
G-AMG's Avatar
Sorry! Got it this time
Sorry folks, I finally got this to upload:
Old 01-29-2007, 01:26 PM   #7 (permalink)
Mr A's Avatar
Date registered: Oct 2006
Vehicle: Black on Black 1999 E320
Send a message via Skype™ to Mr A
http://www.benzworld.org/forums/w210...l-removal.html would probably help also
Mr A is offline   Reply With Quote
Instrument Cluster removal etc zaint10 R171 SLK Class 5 04-01-2006 04:21 AM
Instrument Cluster Removal pcmaher W140 S-Class 4 11-12-2005 08:57 PM
instrument cluster removal hcalmar W124 E,CE,D,TD Class 2 03-14-2005 09:37 AM
Instrument Cluster Removal HELP!!! 300E Guru W124 E,CE,D,TD Class 8 02-11-2004 01:39 PM
Instrument Cluster Removal HELP!!! 300E Guru W124 E,CE,D,TD Class 0 02-09-2004 01:57 PM
