Old 01-19-2007, 06:18 AM   #1 (permalink)
Date registered: Jan 2007
Auto Selector occasional fault
My E240 Yr2000 has been giving me some troubles starting and displaying correct gear lever position. After a number of attempts to move it up/down the gear positions, I get it to recognise that it is either in P or N and can get it to start. Is this a fault with the gear selector module? or more to do with the Neutral Safelty switch? Once the car is warmed up it behaves and always starts in P and drives normally.
Could this be an electrical problem in the selector (dampness,dry joint?) Any suggestions to fix or is it clearly just replace the auto selector module?
thanks for any assistance with this.
gcubbon is offline   Reply With Quote
a170 cdi auto box fault please help wiggi28 W168 A-Class 2 03-20-2008 04:23 AM
Auto Gear Box Fault....i Think! Smifster V-Class 3 12-12-2006 09:59 AM
Occasional fan 88300e W124 E,CE,D,TD Class 5 01-29-2006 05:43 PM
Remomval of Diff lock selector tube and selector sleeve from axles petermerle G-Class 2 06-22-2003 12:38 AM
Auto Gearbox fault on G500L Jim Masterton G-Class 2 07-11-2002 11:00 AM
