Old 01-17-2007, 09:15 PM   #1 (permalink)
kernelguy5's Avatar
Date registered: Jan 2007
Vehicle: 1997 E420 (W210) Sport Package
Send a message via AIM to kernelguy5
Exclamation Wheel Vibrations
I have a '97 E420 and i just put 19 inch brabus rims onto my car. I've balanced and rotated it, but it still seems to vibrate at around 40-55 mph. someone suggested a "speed balance". what exactly what should i do to fix this problem? it's annoying when the steering wheel vibrates continuously.
kernelguy5 is offline   Reply With Quote
Old 01-17-2007, 09:26 PM   #2 (permalink)
Premium Member
acarter53's Avatar
Date registered: Dec 2006
Vehicle: 2001 E430 Sport in Desert Silver and 2002 C320 Sport Wagon in Arctic White
Premium Member
Send a message via Yahoo to acarter53
Question
Are the wheels new or used?
acarter53 is offline   Reply With Quote
Old 01-17-2007, 09:34 PM   #3 (permalink)
kernelguy5's Avatar
they're used, but i know the person who sold it to me, and they weren't used much if at all which is why he sold htem to me in the first place
Old 01-17-2007, 10:23 PM   #4 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Assuming these are genuine Brabus wheels (and not knockoffs) then there shouldn't be anything inherently wrong with them.
Call around and find a quality tire/performance place that does ROAD FORCE balancing; those are your buzzwords. It will cost you, perhaps $20 a tire, but that is pretty much required when you venture into 18" low profile and beyond.
Take care and enjoy smoothing out the ride,
Greg
Meister Eckhart
Old 01-17-2007, 10:48 PM   #5 (permalink)
kernelguy5's Avatar
thanks a bunch greg. yes, they are definitely not knockoffs. I'll definitely do that road force balancing. can't wait to smooth it out
Old 01-18-2007, 12:16 PM   #6 (permalink)
Date registered: Sep 2006
Vehicle: 1996 E320
i know you got them balanced and rotated...but did you get a wheel allignment...cause when u put on new rims...u should definetely get it...that was my issues...that solved the problem...cause i had shaking of steering at higher speeds..for few people wheel allignment has been the issue and i doubt something is wrong with your wheels ..good luck
Creative85 is offline   Reply With Quote
Old 01-18-2007, 04:06 PM   #7 (permalink)
Vehicle: 1996 E320
by the way how do the 19 inch fit...do u hear any rubbing or did u have to get spacers...and do u have any suspension or anything like that..and whats ur tire size...let me know thanks cause i was always interested in putting 19's
Old 01-18-2007, 08:17 PM   #8 (permalink)
Date registered: Jul 2006
A few experienced words of advice..
There are a couple of things - which sound stupid or basic - that you can do first to see if it solves the problem before moving to major...
You have a "resonance" - and generally this is caused by some basic things on a MB, and not necesaarily related to major suspension components.
You try the basic stuff first, then only move on to the major stuff if the simple stuff doesn't work:
a) go to your MB dealer and pick up a assortment of MB wheel weights which are longer and more evenly weighted than most US wheel weights. I have seen US weights fuck up the balance of a MB wheel and cause resonance..
b) take the car back to who ever did the mounting and install and tell them you have a problem.
c) have them pull the wheels off, strip off the old weights, and re-balance using the MB wheel weights (and have them take a better look at the balance too).
d) if you have some funky billet type stem caps - then have those pulled off (you can save them) and replace with plastic for now
e) the wheel bolts need to be re-installed only with hand wrench only, and hand torgue wrench, and must be torgued ONLY in the the order/pattern of tighening shown in any decent manual.
The use of a airtool for retorquing, and/or not using the cross-pattern can fuck you up and cause a resonance vibration
Only after you go thru these basic steps - and they don't work - then have the shop swap your rear wheels/tires back to the front ---
If after these basic steps your resonance doesn't go away - then get a alignment - then after that and it's still there try to find a on-car speed balancing shop (sometimes a truck shop)...
I have seen a lot of people waste a lot of money replacing components, and actually it wasn't the the big shit at all, but it was small shit...
fabbrisd1 is offline   Reply With Quote
Vibrations Judas W140 S-Class 6 11-30-2005 06:05 AM
Vibrations ack W163 M-Class 29 10-14-2005 09:17 AM
Vibrations... Braingears G-Class 9 08-10-2004 08:28 PM
Vibrations in steering wheel wmedia W140 S-Class 8 07-28-2004 07:03 AM
Vibrations..... CustomSLKIOM R170 SLK Class 0 02-27-2003 06:54 AM
