Old 01-15-2007, 08:23 PM   #1 (permalink)
cheeze's Avatar
Date registered: May 2004
Vehicle: E-320 Wagon 1998
Oil Leak
I just developed a good oil leak from th rear part of the engine at 127,000 miles. A search revealed nothing on this site. Maybe the rear seal? Is this a common leak?
NATCA
cheeze is offline   Reply With Quote
Old 01-16-2007, 11:55 AM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
I've not heard of any common oil leaks on the V6 engine.
Rear main seals usually seep more than leak. If by "good oil leak" you mean a substantial amount of oil, it may be a sending unit etc. (It's also possible that you "blew out" the rear main but that's exceedingly rare.)
If you pull the inspection cover for the tranny/engine you'll be more able to see if it's coming from the rear main. There are lots of little lines, ports, sending units, etc. hopefully it's one of those as they're cheap and easy to fix -- relatively speaking, of course.
If it is a substantial leak it may not be safe to drive; if you lose too much oil pressure trying to take it in you could do serious damage to the engine.
Good luck, post back and let us know what it was.
Take care,
Greg
Good luck and enjoy the ride,
Greg
Meister Eckhart
Wiring loom - insulation falling off, water leak, oil leak sjc123456789 W124 E,CE,D,TD Class 3 02-10-2006 11:24 AM
Repair Costs for very slight oil leak at phenolic (sic) oil filler cap, 2001, 320 noelchambers R170 SLK Class 2 11-05-2005 08:53 AM
oil leak... motor honey?...leak stop? b2d W123 E,CE,D,CD,TD,TE Class 1 04-11-2005 04:07 PM
My car is in the shop...Oil leak, windshield washer leak, and screw came off. chanm W163 M-Class 3 05-23-2003 07:21 AM
My 96 S320 to have a cracked engine block gasket, which cause a oil leak .All oil changes (more)... Guest (MBNZ) W140 S-Class 2 04-19-2002 02:34 PM
