Old 01-15-2007, 04:35 AM   #1 (permalink)
Date registered: Jul 2006
Vehicle: 2001 MB E430
Send a message via AIM to BiGbOdYbEnZ430 Send a message via MSN to BiGbOdYbEnZ430
Doing A Tune up
is it possible to do a tune up yourself???? i have a 01 e430, and it really needs a tune up. does it requires special tools or something. please help me out.
BiGbOdYbEnZ430 is offline   Reply With Quote
Old 01-15-2007, 11:17 AM   #2 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
There is no clasic tune up on those cars.
Service is filters/oil change and checking up the items on the list.
At about 100,000 miles you should replace spark plugs.
What is the problem? Do you have any error codes?
Kajtek1 is online now   Reply With Quote
Old 01-15-2007, 12:21 PM   #3 (permalink)
i just bought my first MB. it has about 72K miles. but it think it need a tune up. i already change the oil, and oil filter, MAF sensor, air filter. how do i check the transmission fluid. is there a dipstick? how do you drain it, and refill. is it possible to do it yourself?
Old 01-15-2007, 01:11 PM   #4 (permalink)
Date registered: Dec 2006
Vehicle: 2002, E430, 2002 BMW 530i, 1955 Belair Hardtop
I also just bought an E430, though it's a 2002. Not sure of the maintenance history, so I'm gonna be going through it too. I'm gonna do the oil change, air filter, spark plugs and transmission fluid.
JIM55 is offline   Reply With Quote
Old 01-15-2007, 05:40 PM   #5 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Gents, the search function will reveal a wealth of information on these topics.
There is no mandated "tune up" period. Plugs are generally done by 100K miles, filter intervals are in the owner's manual.
There is no dipstick on the AT, rather a seal cap you have to break to get off. And you need a special tool to check the fluid level, it's based on fluid temperature. Very bizarre. Again, if you search here and the other forums you'll find folks who have done it themselves but it's not like a regular car and if yours is new enough, you won't be able to drain the converter, so you change out less than half the fluid. I'm a big fan of DIY and have pretty decent mechanical chops, but in this case I did a lot of homework before finding a shop I trusted to do it right.
Welcome to the MB club and enjoy the ride,
Greg
Meister Eckhart
Old 04-03-2007, 07:59 AM   #6 (permalink)
Date registered: Nov 2006
Vehicle: 2001 E430
Spark Plugs 5 years or 100k
Recently had my service A completed on 01 E430 w/75k at dealer. Dealer recommended replacing spark plugs soon when I picked up. I thought they were 100k spark plugs, and he said they are but should also be replaced every 5 years. Should I get them replaced, or wait?
Gator is offline   Reply With Quote
Old 04-03-2007, 10:26 AM   #7 (permalink)
gregs210's Avatar
Hey, Gator, welcome to the forum!
And you have to know the dealer is always going to recommend stuff.
Personally I've never heard of a "time limit" on spark plugs.
If the car is running fine, I wouldn't sweat it. Typically plugs go 100K or more; if you do them before that mileage range you'll probably see a modest increase in fuel mileage since the systems compensate for wear on the plugs. Whether that's worth it is a decision only you can make.
FWIW, that kind of dealer nonsense is why so many people find a good indie they can trust.
Take care and enjoy the ride,
Greg
Old 04-03-2007, 11:06 AM   #8 (permalink)
Musikmann's Avatar
I have encountered dealers who attach a time limit and a mileage to certain things (for example brake fluid and antifreeze I think they said were 2 years or X miles). It seems to me that a seasoned tech should be able to look at nearly all the fluids and know if they are fine or need to be replaced (by appearance, smell, or feel).
As far as the spark plugs go, if you are confident with setting the gap, it certainly won't hurt anything to replace them. But, I think I would try to get the 100,000 miles out of them unless the car exhibits symptoms of a mis-fire.
Old 04-03-2007, 12:19 PM   #9 (permalink)
gregs210's Avatar
Hey, MM, I agree absolutely that chemicals can degrade and become contaminated over time, so I agree with a time limit on such things. (Same logic applies to you and I changing our ATF even though MBZ says it's not necessary, no?)
However, as I said, I have never heard any legitimate basis for changing plugs based on a time lapse as opposed to mileage. I suppose if you only drove 1,000 miles a year they might corrode from age/moisture/etc. before you drove 100 years, but other than that, I can't comprehend a reason to set a time-deadline on them.
Greg
Old 04-04-2007, 10:46 AM   #10 (permalink)
Vehicle: 1997 E320, 1997 S320
i still have the original spark plugs on my 97 E320, and i have like 133k miles on it, but it fires fine, and gas mileage it has been the same. should i wait for a sign, or just go ahead and replace the plugs?
tirona is offline   Reply With Quote
Who can i get to tune my G? Who will tune for the most HP...could this be REALLY bad for engine? sceaton G-Class 2 03-19-2006 07:25 AM
to tune or not to tune? aphex1 R230 SL Class 3 12-18-2005 02:38 PM
When do I get a tune up? ALLBIZNISS General Mercedes-Benz 2 12-08-2004 10:25 AM
Tune-up ssanmor W201 190E, D-Class 7 10-05-2003 05:53 AM
Tune Up Guest (MBNZ) W124 E,CE,D,TD Class 3 06-26-2002 01:12 PM
