» Site Navigation » Other Sites
» Network Links
01-14-2007, 07:54 PM
#1 (permalink )
Date registered: Oct 2006
Vehicle: Mercedes Benz E320
••Check Coolant is Driving Me Nutz••
Anyone knows why this message would come and go? All my levels are perfect...I have no idea how to get this message erased from my dashboard...anyone knows what the heck isgoing on?
01-14-2007, 08:04 PM
#2 (permalink )
Vehicle: W211/W210wagon/W209
Test the coolant level sensor.....its a float type sending unit
01-14-2007, 08:05 PM
#3 (permalink )
how you test it?
01-14-2007, 08:12 PM
#4 (permalink )
With a OHM Meter...simple test ....open when low and closed when full
One can test it when its in the car...drain the coolant level..test it ..refill and test again
01-14-2007, 10:19 PM
#5 (permalink )
Date registered: Sep 2006
Vehicle: 1996 E320
If i was you i would also check the water pump...i had same problem...coolant level would come on then go away then come on....and i went to mechanic and my water pump is leaking...so make sure that is checked out or the anti freeze box dont have any leak...
Thread Tools Display Modes Linear Mode
Similar Threads Topic Author Forum Replies Last Post Check Engine and Coolant Light Rjelaine W124 E,CE,D,TD Class 8 09-13-2006 10:35 AM This PSE pump is driving me nutz... sshel96310 W140 S-Class 1 06-05-2006 05:07 PM Service B, Check coolant light fix, C240 4matic loaner maneesh W163 M-Class 1 02-15-2004 03:10 AM Check coolant light coming on maneesh W163 M-Class 8 01-31-2004 02:33 PM 1990 300E check engine, low coolant, stalling too tomer W124 E,CE,D,TD Class 5 08-15-2003 02:46 PM
