Old 01-14-2007, 03:38 AM   #1 (permalink)
Date registered: Aug 2006
Vehicle: 1997 E320 Avantgarde
Mass air flow sensor
Can anyone tell me if there is a way to ascertain if the Mass air flow sensor needs to be replaced? What exactly does it do? Anyone got any pictures of a
Mass air flow sensor?
Thanks
Laksa
laksa is offline   Reply With Quote
Old 01-14-2007, 08:47 AM   #2 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
It will throw a check engine light and the code will tell you it's the MAS, P0100 I think.
Len
sokoloff is offline   Reply With Quote
Old 01-14-2007, 06:03 PM   #3 (permalink)
Date registered: Jul 2006
Vehicle: 2001 MB E430
Send a message via AIM to BiGbOdYbEnZ430 Send a message via MSN to BiGbOdYbEnZ430
yeah...it will a throw a check engine light. i had the same problem not too long ago. replaced the MAS and reset the code. all-set. good as new.
BiGbOdYbEnZ430 is offline   Reply With Quote
Old 01-14-2007, 06:24 PM   #4 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
Maybe newer models have a code for MAF sensor, but not our 98/99 models.
With bad sensor you have several codes displaying fuel trim and misfiring. Our 99 ML320 had 10 errors when that happened and still run OK.
Seems that there is explosion of MAF failure lately. Each section has several topics. I think the most detailed I've seen is in 163 section, that shares the same engines.
MAF measure the flow of air by comparing heated wire temperatures and adjust the fuel accordingly. The wires get dirty over the years and give false readings, costing lower economy.
Replacing MAF and spark plugs gave me 15% higher mileage on my wagon.
Kajtek1 is online now   Reply With Quote
Old 01-15-2007, 04:28 AM   #5 (permalink)
it should be the same code for 99-o2 models. it showed up as a fuel trim code. i tried cleaning the MAS, but it was still giving me the same code. so i changed it instead, an no more check engine light.
Old 01-15-2007, 06:08 AM   #6 (permalink)
My '99 threw a P0100 code which is the MAF code. I just cleaned mine and all seems well again. It's only been a month, so I'm not banking on being totally in the clear yet.
Len
mass air flow sensor benzpimp W202 C-Class 0 02-28-2006 08:14 PM
Mass Air Flow Sensor w210 W210 E50 AMG, E55 AMG 7 11-07-2005 05:02 AM
Mass Air Flow Sensor? jenjenstar W202 C-Class 5 07-21-2005 09:42 AM
mass air flow sensor 247hoopsfan W124 E,CE,D,TD Class 1 07-10-2005 09:11 PM
mass air flow sensor 247hoopsfan W124 E,CE,D,TD Class 0 07-10-2005 05:31 PM
