Old 01-13-2007, 07:17 AM   #1 (permalink)
Date registered: Jul 2006
How do I replace the turn signal "flasher"??
I'm going to LED's. so i need to replace the turn signal flasher or go the resistor route. I have found 3 to 6 ohm 50 watt resistors on the net for $ 2 each, but I prefer to replace the flasher with an electronic unit. I can hear a "clicker" in the left hand dash area, but I am not sure that this is really a working flasher of just a sound unit!!
I have replaced the P21/W4 rear turn signal/tail light bulb with a modified American 1157 LED and the original 1156 front turn signal lamp with an 1156 LED, so the final change is the flasher.
thanks for your help.
Don Brown
doncbrown is offline   Reply With Quote
No turn signal/flasher zumwoll W123 E,CE,D,CD,TD,TE Class 4 01-01-2007 01:23 PM
Clear "euro" turn signal corners - don't you need a reflector? Qualm W124 E,CE,D,TD Class 7 12-05-2006 11:46 AM
Turn signal flasher Sfak G-Class 2 04-22-2004 08:19 AM
Turn signal flasher Nate W201 190E, D-Class 0 09-14-2002 09:14 AM
