Old 01-10-2007, 07:16 PM   #1 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Front Drop coming Friday...
Hey, folks, we all know that on the 210s the gap over the front tire is greater than the one in the rear, and I want to try something a bit different. So -- although I have the full set of Eibachs and Bilsteins (shortened) -- I'm only going to drop the front for the time being. It's only going down about an inch, which will leave the gap in the rear slightly larger than the one in the front, and it should result in a very mild rake to the car, a la the BMW 5 series. I'm thinking it's going to look pretty cool, and will post in some pics afterwards.
Of course it's getting an alignment while in the shop, and then I also get to realign the headlights to account for the rake.
I'm pretty excited about it, first mod I've done in a while.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 01-12-2007, 05:26 PM   #2 (permalink)
gregs210's Avatar
Thumbs up
Hey, Everyone, just got back from the shop.
I think this looks pretty good; rake is less than 1/2".
Have a great weekend...and as always, enjoy the ride!
Greg
Old 01-12-2007, 10:58 PM   #3 (permalink)
chill_babe's Avatar
Date registered: Jun 2006
Vehicle: C230
Greg
hey got your pm, so I had to come look at it looks nice though hope you're enjoying it! have a great weekend too.
chill_babe is offline   Reply With Quote
Old 01-13-2007, 09:01 AM   #4 (permalink)
Premium Member
acarter53's Avatar
Date registered: Dec 2006
Vehicle: 2001 E430 Sport in Desert Silver and 2002 C320 Sport Wagon in Arctic White
Premium Member
Send a message via Yahoo to acarter53
It looks Great! Good call! Are the wheels 18"'s ?
acarter53 is offline   Reply With Quote
Old 01-15-2007, 03:31 PM   #5 (permalink)
gregs210's Avatar
Thanks for the feedback...the wheels are actually off a 211 E-500 with custom lug bolts due to the different ball-seat configuration. And one size smaller tire, 234/45-17 all the way around.
Greg
Old 01-15-2007, 11:40 PM   #6 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Looks great Greg! I'm glad you finally did it!
Take care & enjoy the ride too,
JOE55 is offline   Reply With Quote
Old 01-16-2007, 12:09 AM   #7 (permalink)
Date registered: Mar 2006
Vehicle: 1997 W210 E320, 1999 W163 ML430, 2002 W203 C240
Send a message via AIM to DETANE
I have 20's on mine but still want to drop the car a little because the 20's make it looked raised. do u think this will damage anything? also what type of shocks and springs would be good? thanks in advance
DETANE is offline   Reply With Quote
Old 01-16-2007, 05:38 AM   #8 (permalink)
Avantgarde 1998's Avatar
Date registered: Jan 2006
Vehicle: E200KOMPRESSOR
Wink
Of course i like it greg.!!
MICHALIS :
Avantgarde 1998 is offline   Reply With Quote
Old 01-16-2007, 03:32 PM   #9 (permalink)
gregs210's Avatar
Hi, Detane, haven't seen much from you in a while. Glad that one of us has a life!
If you can stand the ride harshness with the 20s you won't mind the drop. How to do it depends on how much you want to drop it. Often you can change it up to 3/4 inch just with spring-pads, but that depends upon what you already have in there. I may drop the back of mine just a tiny bit by a pad change out, just to lessen the rake a small amount, but I've not decided yet.
If you're already running a thinner pad or you want a more significant drop, Eibach springs are quite popular. If you drop an inch or more you'd also want to go to shorter (sport) shocks, I went with Bilsteins. Depending on the wheel and tire sizes you're running you may not be able to drop it without rolling the fenders. Ultimately I'd suggest that a good performance shop is the best way to go, they'll steer you in the right direction and they'll be responsible if something doesn't line up just right.
Greg
grinding noise coming from front end benz3000 W210 E-Class 3 12-20-2006 01:51 PM
suspension options to drop the front 2" snik W140 S-Class 10 10-12-2006 11:29 PM
Hearing A Rubbing Noise Coming From Right Front Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 0 09-28-2004 06:00 AM
Noise coming from front right wheel well Jamison W140 S-Class 1 05-01-2004 12:25 AM
My M3 coming on Friday... Norb R170 SLK Class 10 10-17-2002 11:14 AM
