Old 01-10-2007, 02:39 PM   #1 (permalink)
Date registered: Dec 2006
Send a message via AIM to gradyjohnson
Exclamation Climate Control Lights
Hi. New to the forum. I purchased a 1997 E320 in November, 2006. Man, do I love this car. The only detractor is the lights will not come on behind the climate control at night. I pulled the unit, but did not see anything that could be replaced. Does the entire unit have to be replaced, or is there a fuse or something I am unaware of?
Also do you have to replace the entire foglamp assembly, or can the bulb be replaced?
Thanks, Im really happy with the car, really nice ride!!!!
gradyjohnson is offline   Reply With Quote
Old 01-10-2007, 03:32 PM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
There's a bulb on the bottom of the climate-control pushbutton-unit.
Old 01-10-2007, 04:16 PM   #3 (permalink)
Date registered: Nov 2006
Vehicle: Oo == oO 98 E320
Fog light: you can replace the bulb
'87 300E: sold after 11years @ 230k & still on the road somewhere in rural Tennessee.
'94 C220 with 93k totalled 10/06 by hit & run broadsiding monster truck: not a scratch or bruise for me
johnamoss is offline   Reply With Quote
Old 01-10-2007, 07:30 PM   #4 (permalink)
Date registered: Sep 2006
Vehicle: 1996 E320
go to the dealer and ask for the bulb for climate control...u have to take it out and its looks like a screw in the middle of the climate control just twist it and the bulb is in there..put the new one and u good to go ...bulb is like 8 dollars i think
Creative85 is offline   Reply With Quote
Old 01-12-2007, 08:52 AM   #5 (permalink)
Thanks ... I love this forum!!!!
Old 01-13-2007, 06:58 AM   #6 (permalink)
Ok ... so I took the little bulb out and I am wondering if anyone has found a source online for the purchase of these little bulbs? No MB dealer very close (50 miles). Also, it appears that a LED would be a much better source for this light, maybe someone has tried this and has a source for an LED replacement
Old 03-26-2007, 03:58 PM   #7 (permalink)
Date registered: Nov 2003
Vehicle: '98 E320
Grady, I've been throught the exercise to replace bulbs in the speed-o/tach assembly, but have never had to pull or "break into" the climate control unit. Now this AM, said unit went dark. How does one remove said climate control unit? Explosives? Wonder Bar? BFH (Hammer)?
Mike
Rudy
mharmes is offline   Reply With Quote
Old 03-26-2007, 04:07 PM   #8 (permalink)
leftlane911's Avatar
Date registered: Jan 2007
Vehicle: '97 E320
Mine has been dead since I bought it, but whenever I tap on it at night it comes right back one. Fonzy!!! Hey!!!
leftlane911 is offline   Reply With Quote
Old 03-26-2007, 05:09 PM   #9 (permalink)
Look closely at the bottom of each AUTO button, and you will see a small horizontal slot. The radio tool fits there. These tools are available from dealers or from aftermarket stereo shops. Insert the tools into the slots (in the correct direction) until they click into place, and use them to withdraw the unit. So easy a .... umm ...
Old 04-04-2007, 06:35 AM   #10 (permalink)
Date registered: Mar 2007
Vehicle: MB E 300 TD, 1998
Hello All.
I'm new of this forum, so I say hi to all of you. I find this forum very good. I mean it. Even if I'm not from States.
I have similar case with climate control, but my bulb shines a little when I dismantled the control. It doesn't shine so much to illuminate the control in the night, I put another bulb to be sure that its not broken, but result is the same. Maybe you have experienced similar case and can give me a clue where to look for solution, I don't want to buy whole panel in such case.
Hope to hear from you.
Thanks in advance.
Jakub
kumbasy is offline   Reply With Quote
climate control lights cardelen1 Audio & Telematics Forum 2 11-20-2005 10:23 AM
No lights for climate control Topcat89 Audio & Telematics Forum 2 09-09-2004 10:08 AM
Climate control lights Topcat89 General Mercedes-Benz 2 09-02-2004 10:47 PM
Climate Control lights are out spdracrrk W126 S,SE,SEC,SEL,SD,SDL Class 3 01-17-2004 10:20 PM
Climate Control lights Benzboy03 W201 190E, D-Class 0 11-01-2002 03:06 PM
