My 98 E320 has been running perfectly. I just took a 1000mile trip from the Bay Area to LA. When I started the car to leave LA, it stalled. This happened several times. I waited 5 minutes and it started and ran. I drove all the way home without stopping. The next day, my wife went to the store. When she got back in the car, it started and stalled again. I went down and got it started and drove home.
The car runs perfectly otherwise. I got 30.5 miles per gallon on the trip. It has 61,000 miles on it with original plugs.
Should I change plugs, or something else?
1984 300D 225,000 miles (hit and totaled by bad driver)
1987 300E 209,000 miles (donated to worthy cause, still going)
1988 300E 205,000 miles (still a daily driver)
1998 E320 70,000 miles (Obsidian, 17' E500 rims)
1990 300CE 88,000 miles (Silver/ black int)
same problem with my 1999 E320 I am replacing the crank positioning sensor. Mine would stall while driving. I would let it sit for a few min. and it would start back up and sometimes drive for days until it would happen again. Got my sensor from All OEM auto parts for $76.00 Dealer wanted $125.00 my local garage is putting it in for $45.00. Dealer told me it was an 1 1/2 hour job. At $85.00 an hour labor you do the math. Some say it is a do it yourself too! but I don't touch electrical repairs. Good luck
There is a pictorial DIY in the sticky thread for this forum on replacement. It is not difficult and it's not really an "electrical repair", just replacing a part that has an electrical connection on it. From that standpoint it's like replacing a headlight bulb. You can find replacements on-line easily enough.
Sometimes they throw codes so you might want to have codes scanned to check, but often they don't throw a code anyway. Nice, huh?
Take care and enjoy the ride,
Greg
It might also be the key going bad. Take spare key with you and see if that would solve the problem.
I replaced my spark plugs at 97k, what with new MAF gave me 15% better mileage. I think more due bad MAF, than plugs, but changing the plugs on 6 cylinders is not as bad as some picture.
CPS replacement at CA dealer is more like $500 job. You are one lucky guy Randall
Mine did the same thing. I would also get an intermitent "SOS visit workshop" message. Mine turned out to be the battery going dead. After several stalls (random days) it simply wouldn't turn over. I didn't think it was the battery because all the electrical stuff seemed to be working fine. I was doing research here on the crank sensor when I decided to see what would happen if I hooked up some jumper cables. Wouldn't you know it turned over and started right up. I replaced the batterry and never had another stall or "SOS" message again.
I just had the crank sensor replaced yesterday. My indie charged $90 for the part and $40 to put it in. Saved me the aggravation of doing it myself- pretty cramped working space.
Hasn't stalled yet, so hopefully no more probs.
