I have a 2000 model E320 wagon, model 210 with some strange problems. First the right side headlamp (inside round one) went out - not the bulb but the wiring. Two days later the the service indicator showed ABS/ESC/ASR failures at the same time. I'm guessing a wiring problem - first I have not tracked down why the bulb will not light, but then almost immdiately afterward the codes were logged. Any known/common problem out there?
Sure, I'll use the quick check. I'm guessing this is related to the service codes & unrelated to the headlight... There is one more item that I didn't mention and didn't think to until reading some other forum topics...the ps oil recently went low and the service indicator alarmed me of it - these all happened in the same 4 or 5 day period. Thanks for your reply.
