Old 12-15-2006, 10:01 AM   #1 (permalink)
Date registered: Aug 2006
Vehicle: E420
Question What noise is this??
Yesterday morning as I turned my key I heard a wierd noise, like those of a shaver or electric advertisement neon lights, coming from the small vent holes on the interior cabin lights unit above the rear view mirror. The noise will go away after a couple of second after you turn the ignition off (the same time you heard a relay click under the dash). The sound is like electric high pitch buzzing / ratling.
Anybody experience this before? Is it something that I should be worry of?
It is very annoying and makes me dizzy.
Hope somebody could tell me how to fix this
Thanks
Frankbenz is offline   Reply With Quote
Old 12-15-2006, 10:11 AM   #2 (permalink)
Mark Cummins's Avatar
Vehicle: W211/W210wagon/W209
You have a couple items there..First a Phone Mic..Second the Cloric Feeler for the Climate control...I Think the noise is from the second item
Mark Cummins is offline   Reply With Quote
Old 12-15-2006, 02:15 PM   #3 (permalink)
Date registered: Dec 2004
By "cloric feeler," Mark means that your cabin air temperature sensor for your climate control is in there. There is a small fan that pushes air across the sensor so that the reading is an accurate of the inside temp. That fan is making the noise.
lexrex is offline   Reply With Quote
Old 12-15-2006, 03:26 PM   #4 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
The fan may just be dirty. You can remove it and blow it out with compressed air. If that doesn't help, a new one is less than $100 online.
You take the lamp assembly loose to service this fan and sensor. Once you remove the lenses, you'll see some small metal clips holding the assembly to the roof. With this loose, disconnect the cable connected to the sensor and twist it to remove. You press straight down and click it into place to install.
Old 12-15-2006, 05:08 PM   #5 (permalink)
Vehicle: E420
Thanks for the inputs. I'll try to 'blow' it with compressed air first, if it's not successful I'll open and clean it.
Will post the result
Frank
Old 03-13-2007, 05:56 AM   #6 (permalink)
vibra's Avatar
Date registered: Feb 2007
Vehicle: AM
Send a message via Yahoo to vibra
without disassembly
without disassembly , will WD-40 help ?
vibra is offline   Reply With Quote
Old 03-13-2007, 02:03 PM   #7 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Um, no. WD-40 is basically kerosene, it will deteriorate all that plastic and the fumes will permeate everything, so you'll smell it for the rest of the car's life.
Meister Eckhart
Old 03-13-2007, 10:38 PM   #8 (permalink)
Vehicle: E420
Hi guys,
Sorry for the late posting. I tried to blow compressed air through the holes but no luck. tried to open the clips but two of them got broken right away, so I stopped and try to live with it. Very sad to see MB's plastic quality. here crack, there crack everywhere cracks....
Have a good MB day
Frank
Old 03-14-2007, 05:24 AM   #9 (permalink)
luckre's Avatar
Date registered: Apr 2006
Vehicle: 1999 CLK 230 K
Hey Frank
I used to have the same problem but my car is CLK W208 I just disconnect the wire and its gone
without any side effects
luckre is offline   Reply With Quote
Old 03-14-2007, 10:47 PM   #10 (permalink)
Vehicle: E420
Without side effect??? so why they have that little fan sucking air inside then?? to read the ambience temp quicker??
Anyway, you might be right, unhooking the wires for the fan may not interfere with the temp sensor itself.
I'll try, thanks for the hint
Rear end noise when break after starting/cold; wind noise from driver side window. zhuorongdeng W203 C-Class 1 07-03-2007 02:59 PM
Lifter noise, miss, black smoke, and noise 1986 500sl Omani R/C107 SL/SLC Class 12 02-22-2005 04:13 AM
"Squealing noise", and high pitched wind noise.... JKRD101 W215 CL Class 0 01-01-2004 03:36 PM
Noise while in SA Douglas Dees G-Class 15 11-19-2002 04:49 PM
Brake Noise: Has anyone solved the problem yet with the ML500 and the MAC Truck Brake noise??? Carmen W163 M-Class 7 02-14-2002 09:21 PM
